We'll soon get camera support :)
(08-13-2020, 05:47 PM)KitsuneAlicia Wrote: Looking at the issue report from the OP, it appears they just updated to add camera support about 10 hours ago as of this writing, though they forgot a crucial part of the image. (i.e. the v4l-utils package that contains the media-ctl binary)
However, until they update the image, you can manually install it using apt in the terminal. (Also be sure to update to the latest development image just in case. Version 140 as of this writing.) I can confirm that camera does indeed work after doing this, although there are still a few issues to note:
1. Switching to the front camera doesn't appear to work yet
2. Camera preview is extremely slow and choppy
3. The picture is reversed
There should be a media-ctl command that lets us fix the 3rd issue, but I don't know enough about it to do so.
Also, for newbies, the commands to install v4l-utils are as follows:
sudo mount -o remount,rw /
sudo apt update
sudo apt install v4l-utils
You may need to reboot after this, but I'm not sure. I rebooted just in case.
Hey thanks for the instructions. For me this did not work however. I'm on devel 143. It said v4l-utils are already installed. So I guess the issue was fixed. My camera app still does not work though. Might I be facing hardware issues? Or do I need to use something other than the camera application to take pictures?
We'll soon get camera support :) - by Luke - 07-03-2020, 12:32 PM
RE: We'll soon get camera support :) - by drpi - 07-03-2020, 03:43 PM
RE: We'll soon get camera support :) - by Luke - 07-03-2020, 03:47 PM
RE: We'll soon get camera support :) - by elastic - 07-03-2020, 04:18 PM
RE: We'll soon get camera support :) - by hiimtye - 07-04-2020, 03:51 PM
RE: We'll soon get camera support :) - by Luke - 07-04-2020, 05:37 PM
RE: We'll soon get camera support :) - by hiimtye - 07-06-2020, 06:07 PM
RE: We'll soon get camera support :) - by hiimtye - 07-12-2020, 03:33 PM
RE: We'll soon get camera support :) - by natasha - 07-21-2020, 05:29 PM
RE: We'll soon get camera support :) - by Luke - 07-22-2020, 06:19 AM
RE: We'll soon get camera support :) - by natasha - 07-22-2020, 01:16 PM
RE: We'll soon get camera support :) - by Momomentum - 08-14-2020, 01:15 AM
RE: We'll soon get camera support :) - by Cree - 08-14-2020, 10:09 AM
  ADB support on Pinephone Sumwun 3 902 09-27-2023, 04:04 PM
Last Post: Sumwun
  Well, we had a camera! Cree 2 4,020 09-16-2020, 12:03 PM
Last Post: Phillip Bell
Question Camera(s) not working? UNi 9 13,901 09-06-2020, 10:45 AM
Last Post: Cree
  The Camera Hobgoblin 0 1,956 09-03-2020, 08:13 AM
Last Post: Hobgoblin
  Ubuntu Touch 6 brings camera to RC channel doelf 2 4,086 09-01-2020, 02:15 PM
Last Post: doelf
  Camera GloriousCoffee 3 4,734 08-04-2020, 08:35 PM
Last Post: daniel
  How to get a camera working? lindertb 3 6,044 05-24-2020, 08:57 PM
Last Post: Engineer
