USB current limit
(07-17-2020, 10:37 PM)HLing Wrote:
(07-17-2020, 02:24 AM)a-wai Wrote: Charging still works fine for me, but I modded my HW, that may be why...
Try running the following command as root (not using sudo, you really need to log in as root) and reboot:
echo "blacklist anx7688" > /etc/modprobe.d/blacklist.conf
Thank you, a-wai! you're a genius! It worked!  (and I did not mod my HW. in fact i was also wondering if it was going to be impossible without modding the HW, until I remembered that up until recently I could charge using USB-c to USB-c).
And this just for my education: When you said that one "really need to log in as root", I did and it worked.  Would it not have worked if I used sudo?
Thank you again for all the brilliant work on Mobian!
If you run sudo echo, the redirection (>) is not privileged. You can do 'echo whatever | sudo tee -a file' instead.
Enviado desde mi ONEPLUS A5010 mediante Tapatalk
USB current limit - by fernando_c_m - 07-01-2020, 01:47 AM
RE: USB current limit - by fernando_c_m - 07-01-2020, 04:56 AM
RE: USB current limit - by fernando_c_m - 07-02-2020, 12:11 AM
RE: USB current limit - by bcnaz - 07-02-2020, 02:39 AM
RE: USB current limit - by devrtz - 07-02-2020, 02:45 AM
RE: USB current limit - by HLing - 07-11-2020, 05:15 PM
RE: USB current limit - by Kareema - 07-15-2020, 09:36 AM
RE: USB current limit - by Alho - 07-16-2020, 07:26 AM
RE: USB current limit - by a-wai - 07-17-2020, 02:24 AM
RE: USB current limit - by HLing - 07-17-2020, 10:37 PM
RE: USB current limit - by e-minguez - 07-17-2020, 11:14 PM
RE: USB current limit - by HLing - 07-29-2020, 08:28 AM
  Anyone know how to start a terminal at current dir with Nemo? rp3 6 5,248 01-19-2021, 10:04 AM
  Current Features working under Debian pcdoodle 1 3,462 05-15-2020, 01:02 PM
Last Post: wasgurd
