pacman 404 errors
If you are seeing a bunch of 404 errors when using command-line 'pacman', you might be able to fix it in 2 easy steps:
1. Edit your /etc/pacman.d/mirrorlist file, so only this line is present:
  Server = https://manjaro.moson.eu/arm-stable/$repo/$arch
2. Now run a complete update and mirror sync with this command:
sudo pacman-mirrors -g && sudo pacman -Syyu
I am sharing this because I struggled for about a week.  One day, pacman just decided to quit, and I spend a lot of time working with mirrors trying to fix it.  Finally, I found this post by strit:
https://forum.manjaro.org/t/another-mirr...red/132302
Along the way, I came across related info, that may or may not be relevant or useful, but here it is anyway:
https://forum.manjaro.org/t/repos-mirror...404/135113
"Manjaro ARM is transitioning to a Boxit Server, which requires a new mirror structure" - April 2020
pacman 404 errors - by Phillip Bell - 06-20-2020, 03:24 PM
  PinebookPro Build Errors mexsudo 3 2,943 01-30-2022, 08:36 AM
Last Post: mexsudo
  Screen refresh delay with kernel errors shawnanastasio 31 38,837 04-27-2021, 02:57 AM
Last Post: james64
  I/O errors from SD card slot? (Manjaro, kernel 5.7) zackw 5 8,533 10-28-2020, 01:16 AM
Last Post: 25519
  manjaro pacman desktop? jcarty 2 3,320 09-13-2020, 04:47 PM
Last Post: carlosqueso
  Keyboard or driver errors - transpositions & multiple chars marawuti 0 1,705 08-18-2020, 10:29 PM
Last Post: marawuti
