n00b questions - can I add additional repos? how is UT different from a "full" ubuntu
(06-19-2020, 08:44 AM)arturo2bodegas Wrote: I am loving my pinephone, but as a linux newbie, it is sometimes frustrating. I'm learning as fast as I can. Here are some of my initial questions about running Ubuntu Touch version 54 on my Pinephone:
1. Can I add additional repos to gain access to additional packages built for the arm64 architecture, or will it break my install?
2. How is Ubuntu Touch different from a full GNU/Linux OS? I get the amd64/arm64 ISA difference, but what am I missing?
3. Once the phone goes to sleep/screen shuts off, it loses wifi connectivity, and I have to restart the phone to reconnect to wifi...is there a fix for that?
4. Is it possible to install Phosh on top of UT, instead of the Unity/Lomiri shell?
Thanks for helping a learner here...I enjoy being part of the FOSS community - this project rocks!
Software for Ubuntu Touch is shipped as click packages (an ancestor for snap packages created for Ubuntu Touch). click packages are distributed via the OpenStore.io, which is the only centralized repository of software for Ubuntu Touch (nothing prevents people from creating others, and the OpenStore was once an alternative the the Ubuntu Store).
On Ubuntu Touch you can also use libertine containers, which allow you too use deb packages from the Ubuntu Archive.
Ubuntu Touch itself is updated with images not packages, and it's rootfs is for safety reasons (including security) read only. This means that you can use deb packages from Ubuntu, but because the rootfs is read-only, by default that's it. I believe that in theory you can make the rootfs, read-write and add extra repositories like on any Ubuntu, however this is not recommend nor supported and is risky and change the rootfs to read-write might lead to breaking your OS or at least it failing to upgrade.
Ubuntu Touch differences to Ubuntu are mostly on how Ubuntu Touch was designed to be more safe than Ubuntu, because having a working phone is usually more critical to people (i.e.: it's used to call for emergency services). This means things like read-only rootfs, apps not being able to freely roam through the OS and user data, but having to use system services and special API, to access resources in controlled ways, click packages that include confinement features, on-the-go permissions system that asks the user if applications should be able to access things like sensors. Additionally both Lomiri, the Ubuntu Touch UI, formerly known as Unity 8, and the frameworks and toolkits, are made in ways that depending on the case are either intentionally designed for, or that just allow to do UI convergence.
The wifi thing you mentioned is PinePhone specific, I don't know more about that issue.
It's not possible to replace Lomiri on Ubuntu Touch, in the sense that UBports hasn't made anything to allow for it, or facilitate it, it would also mean to remake almost everything if anyone else wants do to it, UBports has no intention of doing it.
RE: n00b questions - can I add additional repos? how is UT different from a "full" ubuntu - by Diogo - 07-09-2020, 05:28 AM
  Ubuntu Touch on Pine64 Rondarius 11 3,616 10-11-2023, 12:36 PM
Last Post: Rondarius
  Ubuntu Touch vs Standard Pinephone OS MarsColonist 8 5,936 06-26-2023, 07:50 AM
Last Post: gregb49
  Reinstall Ubuntu Touch on PinePhone with 10 drives? Peter Gamma 4 2,915 05-24-2022, 06:42 AM
Last Post: Peter Gamma
  Ubuntu Touch with OTA updates Luke 131 168,747 04-21-2021, 12:20 PM
Last Post: Nooblife
  UT move to Ubuntu 20.04 Concrete_panda 2 5,271 11-24-2020, 12:43 PM
Last Post: DrewTechs
  How to enable SSH on UBPorts Ubuntu Touch? eaglecup 12 20,245 09-15-2020, 03:42 PM
Last Post: voidmain
  Questions about Immutable Aspect of UBPorts QazTheWsx 3 4,634 09-09-2020, 05:03 AM
Last Post: evilbunny
  Ubuntu Touch 6 brings camera to RC channel doelf 2 4,086 09-01-2020, 02:15 PM
Last Post: doelf
  Ubuntu updater fail, partical win, fail again Msemmett 8 10,700 08-18-2020, 03:43 PM
Last Post: bcnaz
  Ubuntu bootloops on Braveheart lapinus 0 2,064 07-26-2020, 03:45 PM
Last Post: lapinus
