1GB Pine64+ freezes/crashes with all installs
(05-11-2016, 01:50 PM)pinecone Wrote: Been having the problem of whatever OS I run on the 1GB Pine64+ board constantly crashing when, if my suspicions are correct, high memory usage happens. In particular it will always happen when I browse a "heavy" page. Whether it's with Chrome on the Android 5.1 build, Midori on the Arch Linux build, or the browser in RemixOS, it's always the same problem with the same result - after just a few seconds of loading a heavy-ish page, the screen goes black and the device shuts off, or the screen goes black then white, device stays powered on, and the SoC (heatsinked with proper 14x14x20mm heatsink) goes very warm as if the CPU or GPU is working on full throttle.
I doubt it's an overheating issue due to the big heatsink, and the memory chips never really get warm at all. I'm starting to think that there's a defect in some "higher location" in one or both of the memory chips on my board, as the problem seems to occur only when memory usage ramps up. Doing nothing demanding in particular the device runs just fine with every OS I tried. My board has the same slightly bent shape that many others have pointed out theirs have.
Anyone experiencing the same? Do I have some kind of warranty on the board I got via backing the project?
If I were you I would try one of the two current linux builds, Ubuntu or debian. Stay away from gui if you can (potential for more bugs) I would run the stress app to rule out heat/power issues. You can then install memtester and run that to try to test your ram.
It is not impossible that its the ram but its much much more likely that its a power issue.
RE: 1GB Pine64+ freezes/crashes with all installs - by rahlquist - 05-11-2016, 02:05 PM
  Pine64 Suddenly Turnoff with Lcd mix359 4 10,329 07-08-2021, 08:50 AM
Last Post: e-minguez
  Pine64 (analog) Audio Jack Output w/ Kernel 4.19 ecolezen 0 3,147 01-24-2019, 07:00 AM
Last Post: ecolezen
  PINE64 STEREO AUDIO DAC POT jtgiroux 0 3,228 01-12-2019, 04:56 PM
Last Post: jtgiroux
  Does Pine64+ have an internal hardware watchdog ? rahlquist 8 15,347 04-26-2018, 06:27 PM
Last Post: pfeerick
  Using the pine64 with AVR - HDMI pass-through Moshe.Vazan 4 6,257 01-02-2017, 02:58 PM
Last Post: Moshe.Vazan
  I dropped my Pine64 DukeJustice 17 20,609 11-07-2016, 07:23 PM
Last Post: DukeJustice
  pine64+ cad files danlcarr 1 3,706 08-31-2016, 08:26 AM
Last Post: martinayotte
  Pine64+: 3 working, 1 shows nothing on tv zumtra 1 4,014 07-30-2016, 05:47 PM
  mounting root filesystem via NFS on pine64+ issue martind1983 2 4,507 07-29-2016, 06:37 AM
Last Post: martind1983
  Cannot get PINE64 boards to boot andymelton 13 17,317 07-06-2016, 09:20 AM
Last Post: montero65
