Left USB port stopped functioning
This seems to be some sort of issue with the USB drivers in the vendor kernel, I guess. My own unit did the same when I was using the Debian install that the first units shipped with. For what it's worth, the issue totally vanished when I switched to Manjaro (which uses the mainline kernel). If you can find a distro that gives you a mainline 5.6 kernel and suits your needs, you might also find it solved.
If you prefer Debian over Manjaro because you prefer older, more stable software, I understand - but do consider that the Pinebook Pro itself is not really very old or stable hardware yet, and it might be much better-served by a distro that has more up-to-date packages than Debian typically offers.
RE: Left USB port stopped functioning - by diodelass - 06-07-2020, 01:43 PM
  HDMI and PBP USB C port IMSAI8080 0 1,130 09-26-2022, 09:17 AM
Last Post: IMSAI8080
  Pinebook Pro Docking Deck Ethernet Port MickTheGeek 1 2,491 06-16-2021, 07:49 PM
Last Post: Kuawi
Photo PineBook Docking Deck charging port? ColoBill 3 5,317 02-26-2021, 10:07 PM
Last Post: Paull
  Some keys have stopped working wsgts 1 2,911 04-07-2020, 06:24 AM
Last Post: wsgts
  Port Adapters for PBP — Ethernet, HDMI, etc. zaius 18 23,407 01-19-2020, 03:52 PM
Last Post: Arwen
  Left-side USB 3.0 port not working diodelass 6 8,038 11-09-2019, 03:18 AM
Last Post: tgrauss
