Software Compatibility, If on Pi then?
(06-06-2020, 06:59 AM)rossk Wrote: I don't know what "software center" refers to, but you should be able to open a terminal, type "pamac install calibre", follow the prompts and you'll have a working app!
You may find most of what you want in the Manjaro repo's already.
I used the wrong term for the "Add/Remove Software" men, which has a nice selection of software but few programs work.
Reinstalling with "pacman -S calibre" worked perfect, thank you!
RE: Software Compatibility, If on Pi then? - by chetchinglo - 06-06-2020, 07:11 PM
  Error trying to update Manjaro software boosterh 5 2,881 08-31-2022, 10:28 PM
Last Post: shulamy
  Manjaro and Arch repository with privacy oriented software as400 86 114,013 04-27-2022, 07:44 AM
Last Post: annahellrothsparent
  software request: LuckyBackup mexsudo 2 2,099 11-25-2021, 05:59 AM
Last Post: mexsudo
  Running x86 software GloriousCoffee 19 23,958 02-15-2021, 11:43 AM
Last Post: jiyong
  Where to find a PDF viewer (and other software) compatible with aarch64? mjc 8 8,882 09-29-2020, 07:55 AM
Last Post: hmuller
  Package compatibility fcs 6 7,880 04-10-2020, 01:49 PM
Last Post: rempfer
  Arm supported software nabeel 1 2,562 03-18-2020, 08:47 AM
