Pine A64+ mainline mipi-dsi
  Kernel 5.6 is out and mipi-dsi is finally in there, so the pine lcd screen (feiyang) should now finally work with the mainline kernel.
  Can anyone say how to set this up?  Armbian is available with this kernel through build scripts and nightly builds, but I can't work out how to set up uboot, to initialize the mipi-dsi pipeline.
Any help greatly appreciated!
BR.
--Learnincurve--
Probably it has to be done in the dts and not in uboot.
You're quite right.
There is now a working sopine64 image with the correct DTS, however, I'm not techie enough to be able to take that and apply the pine64+ addressing.
Was reckoning, that as the kernel to fully support mipi-dsi is now available, that others would also be intersted and that a DTS tree or patches might already be available.
I think this is the patch for the sopine64:
https://github.com/GavinBa/build/blob/am....dts.patch
The latest Armbian images now fully support the 7" pine64 touchscreen, including DT bindings.
When using Armbian with the screen, disregard the instruction on the Armbian Pine64 download page to enable the screen by setting
"pine64_lcd=on"
in /boot/armbianEnv.txt
Instead, use the hardware category in the armbian-config utility.
The module to load for the touchscreen is "goodix". Not "gt9xxf_ts" as instructen on the Armbian download page.
There is an issue with the goodix touchscreen when rebooting. The goodixi2c connection sometimes fails. The workaround for this for the moment is to shutdown and cold boot.
  DietPi OS for PINE A64 MichaIng 0 9,170 12-15-2020, 06:11 AM
Last Post: MichaIng
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 5,476 10-02-2020, 11:38 AM
Last Post: mathiraj
  Trying new MIPI-DSI code for the touch panel Learnincurve 10 17,081 05-05-2020, 04:57 AM
Last Post: Learnincurve
  LibreELEC(KODI) for Pine A64 (+) pineadmin 6 15,714 05-02-2020, 10:29 AM
Last Post: aaronmarsh632
  Lakka-nightlies for Pine A64 (and H64) roel 11 19,305 04-23-2020, 12:55 AM
Last Post: roel
  Read DHT22 on Pine A64 ayufan 3 6,602 01-19-2020, 02:51 PM
Last Post: {-DesT-}
  Centos 7 for Pine A64 Luke 2 6,070 05-28-2019, 12:18 AM
Last Post: pineadmin
  NEMS Linux for Pine A64 (+) Luke 1 5,133 05-09-2019, 05:42 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,251 03-30-2019, 06:48 AM
Last Post: ktaragorn
  +LTS/SOPINE +PINEBOOK Mainline Armbian for A64 boards Luke 0 2,577 01-12-2019, 06:35 AM
Last Post: Luke
