This board
1. Doesn't have a search feature, or it hides.  Maybe I found it once.  I'd like to look up references to u-boot on the PBP because now that I have all the hardware to install my new SSD I have no idea how.  I'd like to use grub-uboot and have the boot menu select Linux and OpenBSD (the PBP should be a mainstream OpenBSD platform as of about OpenBSD 6.7).
2. It doesn't email me, ever.  I can subscribe to a topic and specify that I want emails on replies, I never get any.  My email address in my profile is correct.  I get emails from the Pine Store OK.
3. Posting pictures is weird and doesn't seem to work, even when I put them on Imgur and link them here.
These might be just configuration options in the board software.  I'm sort of used to having them work on other boards.
, [Image: mRYOzK6.png]
1) Search is there ^ You can actually get pretty good results using it too if you specify the subforum, username of the person associated with the post and the keyword.
2) Strange, I've not had this problem - perhaps all notifications are going to spam?
3) I usually upload whatever I want to include up on imgur and then just paste the link (example: the searchbar in this post).
Wot about that "Custom" field in the left column of our profiles, can we edit that?
https://docs.mybb.com/1.6/Admin-CP-Confi...le-Fields/
OK, you don't try to use the image button then. When I paste a link to a picture I mostly get a link, not a picture, but the image button is less useful. https://forum.pine64.org/showthread.php?...9#pid62639 is an example, there are a couple screenshots in my post in page 6. You probably can't just write the html to stick them in yourself I assume (didn't try). Like <img src="https://imgur.com/a/FdbgUtk"> I don't "do" drag and drop.
If other people get emails, then OK, it's just something I'm doing.
I usually look for the closest search button to whatever topic I'm reading, because I don't want to search everything. Like from that coronavirus page above I can't see a search button, even if I go out to News.
China's quarantine is a model for the rest of the world BTW, it'll probably take months to get it figured out here.
MyBB uses MyCode for markup.
https://docs.mybb.com/1.6/MyCode/
[img]https://upload.wikimedia.org/wikipedia/commons/thumb/5/5d/Pseudotsuga_japonica_togasawara04.jpg/282px-Pseudotsuga_japonica_togasawara04.jpg[/img]
yields
[Image: 282px-Pseudotsuga_japonica_togasawara04.jpg]
Or if you don't want it to be lost when the image host goes down or purges files, attach it, preview the post to get the URL, and use,
[img]https://forum.pine64.org/attachment.php?aid=1723[/img]
[Image: attachment.php?aid=1723]
You can use the above image embedding code in other posts as well, you don't have to reattach it every time.
.jpg   320px-Pseudotsuga_sinsensis_var._sinensis.JPG (Size: 26.17 KB / Downloads: 780)
Got the image thing, unless I forget, thanks.  They're like code or quote
tags, I've seen them around.  I thought you had to use some other host for the image file so it didn't take space here.
[Image: BNgWjgE.png]
Search: how about search within a thread? I've been using Daniel Thompson's Bullseye for a couple weeks, thread https://forum.pine64.org/showthread.php?tid=8487 and I notice a couple of things about the panfrost he uses, but there are 41 pages of discussion.
It seems slower than whatever the mrfixit stretch uses, and I'm getting gobs of purging messages in my dmesg.
(01-07-2021, 10:22 AM)ab1jx Wrote: Search: how about search within a thread?  I've been using Daniel Thompson's Bullseye for a couple weeks, thread https://forum.pine64.org/showthread.php?tid=8487 and I notice a couple of things about the panfrost he uses, but there are 41 pages of discussion.
Some times it's easier to use a traditional search engine over a forum search,
using duckduckgo, the trick is to use the "site:" prefix and then the key words, failing that google is sometimes better as search
https://duckduckgo.com/?q=site%3Aforum.p...ave&ia=web
  A post about a Pine-64 Wi-Fi ethernet router project board and enclosure? Omnios 1 669 09-21-2023, 07:52 AM
  Is it possible to use Pine-64 board as a Mini PC such as BeeLink? Omnios 1 857 08-30-2023, 04:23 PM
  Which Pine64 single-board computer has NO on-board wireless modules? peteressive 2 1,380 03-10-2023, 03:35 PM
Last Post: peteressive
  Article: Automated Testing of Apache NuttX RTOS on PineDio Stack BL604 RISC-V Board lupyuen 0 952 05-21-2022, 09:36 PM
Last Post: lupyuen
  Article: The Things Network on PineDio Stack BL604 RISC-V Board lupyuen 0 1,349 09-20-2021, 08:40 PM
Last Post: lupyuen
  Article: LoRaWAN on PineDio Stack BL604 RISC-V Board lupyuen 0 1,338 09-15-2021, 09:27 PM
Last Post: lupyuen
  Article: PineDio Stack BL604 RISC-V Board: Testing The Prototype lupyuen 2 2,530 08-29-2021, 10:19 AM
Last Post: lupyuen
  Article: uLisp and Blockly on PineCone BL602 RISC-V Board lupyuen 3 3,777 05-21-2021, 11:58 PM
Last Post: nimblemotors
  Article: PineCone BL602 RISC-V Board Receives LoRa Packets lupyuen 0 1,600 04-04-2021, 03:53 AM
Last Post: lupyuen
  Article: RAKwireless WisBlock talks LoRa with PineCone BL602 RISC-V Board lupyuen 2 2,812 03-11-2021, 03:29 AM
Last Post: lupyuen
