PureOS on Pinephone
#81
All,
Long time ago I did some development on the OpenMoko and Casio BE300 Linux port, and last week I received my PinePhone, tried a couple of distro's and decided to take the PureOS route for now.
I successfully build my first image using kernel from Phosh image and injecting it into a Librem 5 image thanks to the instructions from mozzwald.
Next step is to compile my own kernel instead of extracting the one form Phosh, and eventually also building the Librem image myself.
Anyone on here actively working on the PureOS flavor ? Anyone keeping track of the list of issues ?
Cheers,
Filip.
The download server seems to be down - is @clover still working on this port?
Just learned about it due the 13 distro-boot-image and was by far the snappiest of all - would like to dig deeper into this one
I will look into why the download server is down, but i've paused development on this until the bullseye images are in better shape. Buster is too old to keep up with upstream phosh.
@clover Any news?
Hi all,
I am trying to get pureos to boot on my PP64. I followed Mozzwald's instructions at __https://gist.github.com/mozzwald/3104aadf2cc8f567a72b6b7837164f69. All commands seemed to complete with no errors. The changes to his instructions that I made were:
1. For line 14, I used the 20210529-0206-postmarketOS-v21.03-phosh-6-pine64-pinephone.img instead of the pine-pinephone-20200218-phosh.img.xz file that he used.
All other files used were the same as in the instructions.
After flashing the librem5.img to the eMMC on the PP and rebooting, I'm getting a solid red power light and a blank screen. Flashing the librem5.img to a 128GB SD card produces the same result: no boot, blank screen. So, it seems to me there is a problem with the compiled librem5.img file, but I have no idea what it might be. Anybody have any ideas? TIA for any assistance provided.
ssilvi
That guide was created before the 3gb version of the phone. I remember none of the images worked on the 3gb version before some update.
"A newly installed OS does not boot on 3GB PinePhone. U-Boot did not have support for A64 chips with 3GB RAM, and un-patched versions will fail to boot on 3GB (Convergence Package) PinePhones. The patch/commit required is titled: "sunxi: support asymmetric dual rank DRAM on A64/R40" source
(06-11-2021, 06:19 AM)Nooblife Wrote: That guide was created before the 3gb version of the phone. I remember none of the images worked on the 3gb version before some update.
Yes I found that out. The scripts on github by mozzwald and rufferson for creating a PureOS image for the PP do not boot on the 3GB PP 64 model. Does any know how to modify a PureOS image for the PP 3GB? I haven't been able to find anything on the net.
I'll take that as a "no", since nobody has responded. BTW, there are some scripts by rufferson on Github (h t t p s://github.com/rufferson/pureos-pinephone/issues/3) that should compile a PureOS image that WILL boot on the PP64 3GB (I tested this once and was able to boot PureOS successfully). However, I'm unable to successfully reinstall because I don't remember the exact sequence of steps I used the first time.
@ssilvi
Check our forum wiki, there is quite a bit of information there on the Pure OS, including a 'How to' link to mozzwald.com
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(07-30-2021, 08:12 PM)bcnaz Wrote: @ssilvi
The mozzwald script was created for the PP64 2GB model; the build that script creates will NOT boot on the 3GB model. Github contributor 'rufferson' has created some scripts that create a bootable PureOS image for the PP64, which I successfully installed a while back. However, I needed to recreate and install that image but couldn't because I couldn't remember the exact sequence of steps that are required. This is why I was asking if anyone else had been able to boot a PureOS image to the PP64 3GB version.
delta1071
  Using Signal on PinePhone in mid-2023? dante404 47 15,405 05-03-2024, 02:19 AM
Last Post: dragonhospital
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 26,257 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 4,578 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 644 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,638 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 25,826 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,354 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 104,459 11-17-2023, 08:37 AM
Last Post: Uturn
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,145 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,695 10-24-2023, 08:57 AM
