Is there another link for Android images?
I ask this because ayufan's page doesn't load at all due to error messages. The Pine's Android 6.0 build has the corrupt SD card issue. I'm aware the problem has been fixed, but I'm unable to access Ayufan's latest images due to his website issues. Tried two different machines including my ipad and the webpage issues are persistent.
Have you tried using the Pine Etcher installer to download the image(s)?
(10-07-2019, 06:58 AM)tophneal Wrote: Have you tried using the Pine Etcher installer to download the image(s)?
First, thank you for your reply. I did. It only downloads the versions on the pine wiki page which has the SD corruption version of the images. I've been able to get around it by not formatting the "corrupted image." At the same time; in Windows, it shows the separate partitions. In linux, it shows the whole drive as "unallocated." I'm using a 128 GB Samsung Evo card which is genuine (via testing tools). I'm working on trying to resize the partition to use the remaining 64 GB.
Odd. I was just able to get to ayufan's repo for Marshmallow on the Pine, though. Is this the version you wanted? https://github.com/ayufan-pine64/android...r34.img.gz
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 389,041 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,762 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,865 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,000 12-03-2019, 09:52 AM
Last Post: hangglider
Question Android SDK Oreo NGC6691 2 5,628 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,350 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 259,032 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,556 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,417 02-10-2019, 07:44 PM
Last Post: mmmarcus
  +LTS/SOPINE Android SDK support and Customization biplab777 1 4,685 01-07-2019, 01:21 AM
