Any Bitcoin enthusiasts?
Question
Looking to make a portable node with battery supply and touch screen.
Got any links or personal experience with:
  • Batteries?
  • Touch screens?
  • 3D printed case designs?
I have a 12v lithium battery that I tried to plug in but I think it is currently too drained to power it. when I plugged in the power supply, it went into a state where the power light was flashing. I think we would need a charging board to go with a battery like the RPi uses. It could be plugged into the power header. not sure if we will be able to get battery charge level though.
they have a case called the playbox that fits their touchscreen. honestly it is likely cheaper to get that verses printing your own. the current issue is we don't have a battery for this.
I'm asking a friend if the battery I have is a 12v battery.
What I hope to achieve with a custom case is bundling the power supply so the node can be portable (battery) and then plugged into a socket to charge it. It could be a good point of reference for prototyping though.
the battery I was trying was only a 3.7v battery so that is why it didn't work.
Verium miner  Idea trying to make veriumMiner work properly.
I have actually bought this board to install Debian on it, install Bitcoin Core and c-lightning and run these 2 nodes on it! But I'm still getting used to things.
(08-31-2018, 06:30 PM)duckkcud Wrote: Looking to make a portable node with battery supply and touch screen.
  • Batteries?
  • Touch screens?
MyNode has an edition for the RockPro64. I am pleased that Pine sells 18650 battery cases; my use case is a personal server and these help avoid downtime. If you like bitcoin and SBC, you might enjoy Urbit and dasfeb.industries.
