I can not connect adb using USB-C or TCP.
- Using USB type C to C
no device
- Using tcp(ping is succeed)
adb connect 192.168.1.134
unable to connect to 192.168.1.134:5555: Connection refused
If someone succeeds, please help me.
Thank you!
08-28-2018, 05:12 AM
(This post was last modified: 08-28-2018, 06:08 AM by Firesped.)
I'm also trying to get this working. when I plugged into the USB 2.0 OTG port. nothing happened. I found a type-c to type-a cable and plugged it in. my computer recognized a new device.
I am using adb to sideload gapps from opengapps.org.
however the signature verification failed.
error: 21
it seems to be timing out at around 50% of file transfer.
I have the exact same problem.
adb devices return no device.
adb connect is falling despite that the ping is working.
I did try on android 7 and android 8. I also tried on all usb 2 ports. For usb c, I use a hub c to 3 and connect it to the MacBook pro. Also note that I tried on a MacPro with ubuntu.
lsusb on both machines, never show the rockpro64 :/ and adb is not working.
On the device itself I am developer mode and try all transfer mode possible (MTP, PTP...)
please help!
Actually, I bought a usb c to usb 3 and it works now.
