08-15-2017, 12:11 AM
Getting only --disable-pinch in there, and not --enable-pinch requires some tweaking. However, it doesn't help on the pinebook.
Disable pinch-to-zoom in chromium
08-23-2017, 11:38 AM
I've tried
Code: chromium-browser --disable-pinch %U Output of htop: Code: /usr/lib/chromium-browser/chromium-browser --enable-pinch --disable-pinch Still not working, does anyone have any idea? As a side note, is the two finger zoom being emulated in the hardware (ctrl + +), at the kernel level or in the software? possible to completely disable it?
08-25-2017, 08:51 AM
that's weird that you're still getting both flags... how did you make the change?
it is in hardware. I am hoping for some kind of hw register we could tweak or something. @Mark you seem to work for pine, can you help us get documentation for the H2168 controller?
08-30-2017, 11:07 PM
Just from the terminal
08-31-2017, 05:40 AM
Try to do this:
Open chrome://flags/#touch-events and disable it - will it help?
08-31-2017, 06:00 AM
(08-30-2017, 11:07 PM)machinehum Wrote: Just from the terminal if you just run chromium-browser you are running a script which adds the --enable-pinch flag. The real binary is buried in /usr/lib/. Open /usr/bin/chromium-browser with a text editor, you'll see what's going on |
Chromium OS? | Devilotx | 4 | 8,083 |
01-31-2019, 03:19 AM Last Post: soupbowl |
Problems using Spotify Web version because DRM (Firefox & Chromium) | Ekkaia | 6 | 9,109 |
09-07-2018, 02:23 AM Last Post: JerrySmith1021 |
Disable Bottom Part of Touchpad (where the buttons are)? | dahni | 1 | 3,196 |
09-28-2017, 12:46 AM Last Post: dahni |
Installing VS Code (& Chromium) | Prophesi | 21 | 30,901 |
09-13-2017, 03:27 PM Last Post: DigitalStefan |
Chromium for Q4OS | q4osteam | 0 | 2,611 |
06-21-2017, 08:09 AM Last Post: q4osteam |
