Plex Media Server and Plex Player on Android
Hello Plex64 fans,
I managed to install Plex Media Server and the Player on the Pine64. It runs well, 1080p flawlessly, 4k, not so much.
Here's how to get it done:
  1. Install Android 7 TV
  2. Install Plex for Android from the Play Store
  3. Install Plex Media Server
    • Download the apk: https://apkplz.com/android-apps/plex-media-server
    • Copy it to a USB drive, plug it in the Pine
    • Open ES File Explorer on the Pine64 and install the app
    • Open Android Settings > Apps > Plex Media Server - "Open"
    • It will set itself up, ask for folders. Just follow the prompts.
    • Finally, it will tell you to open Plex Player you installed in Step #2. Do so.
    • Plex Player will ask you to link a Plex account on your PC by visiting https://plex.tv/link. Go ahead.
  4. Setup Plex Media Server
    • On the Pine, go to Network Settings > Ethernet - jot down the IP address. e.g. 192.168.1.128
    • On a computer open that IP address to port 32400. e.g. http://192.168.1.128:32400
    • Your good old Plex Media Server interface will show up.
      • Log in with your Plex Account
      • Set up media folders.
      • Enjoy.
You should be able to use any Android version (tested it on the official Android 6 release as well). Remix OS won't install the Plex Media Server.
Hope that helps Smile
You posted in the linux section. I've seen a lot of questions regarding plex both on here and in the IRC, so I will move and sticky the thread in android general .
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 389,595 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,791 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,876 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,005 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,080 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,633 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,354 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 259,262 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,558 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,458 02-10-2019, 07:44 PM
Last Post: mmmarcus
