NOOB: Z Wave discovery in OpenHAB help needed
Hi All,
I've bought the Pine64 2GB and Z Wave module (EU version) to automate my home using OpenHAB.
As I am a total NOOB at this, I decided to first create a small Z Wave network using 2 Domitech Z Wave smart LED light bulbs only.
I immediately got stuck:
- I've installed OpenHAB on my Pine64.
- In Paper UI on Configureation->Things page, I see the Z Wave Serial Controller: 'online' (connected to /dev/ttyS2).
- I then try to get the controller to get into discovery mode by pressing the big '+', select Zwave binding.
- For 30 seconds it shows a rotating arrow, within that time I put one bulb in discovery mode.
- The bulb does not get 'discovered'.
Am I doing something wrong?
Is there any way to tell if the Z Wave device is really in discovery mode?
Need help here...
(10-22-2016, 01:43 AM)JamesWatt Wrote: Hi All,
Need help here...
Hi JamesWatt,
First thing you need to check is your devices pairing with other controller before, if yes, you require do exclude first.
Need help here...
Hi JamesWatt,
Hi Klliew,
I cannot check that.
All Z Wave devices that I have are the Pine64 ZWave module and those 2 Domitech Bulbs (freshly purchased, new out of box).
I only attempted to pair one at a time (I am using only 1 light socket), both are not detected.
In openhab log I see the text '[ERROR] [ve.internal.protocol.ZWaveController] - Neither inclusion nor exclusion was active!'
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 190 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 2,949 02-02-2021, 12:13 AM
Last Post: PineSupporter
  Help a noob Maverick106 1 3,283 09-29-2020, 10:21 PM
Last Post: pfeerick
  Getting z-wave module working under ubuntu marcosti 6 12,121 02-10-2017, 07:53 AM
Last Post: JamesWatt
  My personal discovery of no video upon first booting my Pine A64 AZ_Ron 3 5,531 08-17-2016, 02:10 PM
Last Post: efalsken
  Is HDCP absolutely needed? diwou 7 8,982 06-21-2016, 05:28 PM
Last Post: diwou
  Pine64 Boot help needed jousley 4 6,225 06-15-2016, 10:35 AM
Last Post: jl_678
  <Noob - My experience setting up Remix OS BeerSnob 3 6,067 06-15-2016, 09:22 AM
Last Post: BeerSnob
  Help needed Install Android using Mac OS X gubaguba 4 7,088 03-23-2016, 05:51 AM
Last Post: Andrew2
