pinephone no longer receiving calls or texts
My pinephone is no longer getting calls or texts, and I'm trying to understand why. A while back I had a similar problem, wherein the model seemed clogged:
forum.pine64.org/showthread.php?tid=16939&page=2
But, I never actually got the bottom of that. I've tried using mmcli to see the stored messages:
mmcli -m 0 AT+CPMS?
But it just returns information about the modem (copied below). Does anyone know what might be going on?
  General  |              dbus path: /org/freedesktop/ModemManager1/Modem/0
          |              device id: b6df770f2cdf2a32fe9b70af378e85fcc9b3e3b8
  Hardware |            manufacturer: QUALCOMM INCORPORATED
          |                  model: QUECTEL Mobile Broadband Module
          |      firmware revision: EG25GGBR07A08M2G
          |          carrier config: hVoLTE-Verizon
          | carrier config revision: 05010141
          |            h/w revision: 10000
          |              supported: gsm-umts, lte
          |                current: gsm-umts, lte
          |            equipment id: 860195051746581
  System  |                  device: /sys/devices/platform/soc/1c1b000.usb/usb3/3-1
          |                drivers: qmi_wwan, option1
          |                  plugin: quectel
          |            primary port: cdc-wdm0
          |                  ports: cdc-wdm0 (qmi), ttyUSB0 (qcdm), ttyUSB1 (gps),
          |                          ttyUSB2 (at), ttyUSB3 (at), wwan0 (net)
  Numbers  |                    own: --------
  Status  |                    lock: sim-pin2
          |          unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
          |                  state: connected
          |            power state: on
          |            access tech: lte
          |          signal quality: 52% (recent)
  Modes    |              supported: allowed: 2g; preferred: none
          |                          allowed: 3g; preferred: none
          |                          allowed: 4g; preferred: none
          |                          allowed: 2g, 3g; preferred: 3g
          |                          allowed: 2g, 3g; preferred: 2g
          |                          allowed: 2g, 4g; preferred: 4g
          |                          allowed: 2g, 4g; preferred: 2g
          |                          allowed: 3g, 4g; preferred: 4g
          |                          allowed: 3g, 4g; preferred: 3g
          |                          allowed: 2g, 3g, 4g; preferred: 4g
          |                          allowed: 2g, 3g, 4g; preferred: 3g
          |                          allowed: 2g, 3g, 4g; preferred: 2g
          |                current: allowed: 2g, 3g, 4g; preferred: 2g
  Bands    |              supported: egsm, dcs, pcs, g850, utran-1, utran-4, utran-6, utran-5,
          |                          utran-8, utran-2, eutran-1, eutran-2, eutran-3, eutran-4, eutran-5,
          |                          eutran-7, eutran-8, eutran-12, eutran-13, eutran-18, eutran-19,
          |                          eutran-20, eutran-25, eutran-26, eutran-28, eutran-38, eutran-39,
          |                          eutran-40, eutran-41, utran-19
          |                current: egsm, dcs, pcs, g850, utran-1, utran-4, utran-6, utran-5,
  IP      |              supported: ipv4, ipv6, ipv4v6
  3GPP    |                    imei: 860195051746581
          |            operator id: 311480
          |          operator name: Verizon
          |            registration: home
  SIM      |              dbus path: /org/freedesktop/ModemManager1/SIM/0
  Bearer  |              dbus path: /org/freedesktop/ModemManager1/Bearer/
(06-01-2023, 07:13 PM)jyoung Wrote: But, I never actually got the bottom of that. I've tried using mmcli to see the stored messages:
mmcli -m 0 AT+CPMS?
Try these commands. I used these for a long time.
The sms number on the delete line comes from the first command
mmcli -m any --messaging-list-sms
sudo mmcli -m any --messaging-delete-sms=7
sudo systemctl restart eg25-manager.service
==Another note==
I never got stuck messages after I flashed my modem with Biktorgj's firmware.
See this video: https://youtu.be/QgFtFzPhXJw
My devices:
PinePhone 16G
PinePhone Pro
Both running DanctNIX Arch Linux Arm with Phosh
Provider: USA Patriot Mobile (T-Mobile)
mmcli -m 0 AT+CPMS?
==Another note==
My devices:
PinePhone 16G
PinePhone Pro
Interesting, when I run
I get
No sms messages were found
mmcli -m 0 AT+CPMS?
==Another note==
My devices:
PinePhone 16G
PinePhone Pro
I get
This is kind of an old thread, but I'm still working on this issue. The current state of the phone is that it can receive calls, but not texts. I attempted to flash the firmware, as in the youtube linked above, but the first step is to install gnome-firwmare. That worked, but the gnome-firwmare app didn't detect the modem's firmware, only the display's. Still hunting for a solution..
  Pinephone won't boot. spha 13 3,382 05-15-2024, 10:31 PM
Last Post: Richy_T
  Pinephone boot. Richy_T 5 343 05-15-2024, 03:35 PM
Last Post: Richy_T
  eSIM on PinePhone just_a_q 4 2,884 05-14-2024, 01:35 PM
  PinePhone - boot from microSD laserpyramid 9 1,118 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 567 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 383 04-02-2024, 11:50 AM
  4G VoLTE calls confirmed working with carrier x dcinoz 15 12,466 03-09-2024, 11:38 PM
Last Post: dcinoz
  Are you using the Pinephone as your daily driver? jro 157 113,942 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 2,161 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 784 01-19-2024, 01:29 PM
Last Post: fxc
