Pinephone & Nexdock
I got one of the Nexdock things that Purism is selling and I really like it.  I no longer need to tether the phone to a laptop for certain mobile uses - I can simply use the relevant apps and data directly on the phone now.  One odd behavior I am seeing is the screen going black for a couple seconds 2-4 times per minute.  I don't see this behavior when the Nexdock is connected to my Juno tablet (with mobian) so it's apparently not endemic to the dock.
Does anyone else have experience with a Nexdock and Pinephone?  I'd sure like to get some clues to the source of this issue.
For me modem activity will cause this on certain frequencies.
And for me those frequencies are 4G - with 3G or lower this does not happen.
This is also a "known" issue but really difficult (or impossible) to solve
De-coupling the shield on the connecting cable may help. Disconnect it on one end but not the other, if you can. (This likely won't be easy.)
Or try some snap-on ferrites.
:wq
[ SRA accepts you ]
I had an unexpected week on the road during which I was able to get much more use from the Nexdock, and I observed that the blanking happens either frequently/regularly or not at all.  It kinda seems like maybe it doesn't happen if the phone has been recently booted but I need to start keeping a log to see if I can get data rather than anecdotes.
  Pinephone won't boot. spha 13 3,146 05-15-2024, 10:31 PM
Last Post: Richy_T
  Pinephone boot. Richy_T 5 252 05-15-2024, 03:35 PM
Last Post: Richy_T
  eSIM on PinePhone just_a_q 4 2,786 05-14-2024, 01:35 PM
  PinePhone - boot from microSD laserpyramid 9 983 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 491 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 333 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 112,498 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 2,016 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 721 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,688 12-28-2023, 07:55 AM
Last Post: MTXP
