Install Tow-Boot on the SPI
Maybe the new release of Tow-boot finally fixes the black screen issues on 2020 Pinebook Pros: https://github.com/Tow-Boot/Tow-Boot/rel...022.07-006
I read somewhere that upstream Uboot has this fixed and the rebased new version of tow-boot should have this now as well.
Edit: tested it and it seems to work with my early 2020 Pinebook Pro.
Thumbs Up
Quote:I hope this helps others.
It did, just tried it on my recent PBP. Boots the stock Manjaro flawlessly, except for a short graphical glitch before the Manjaro logo appears.
(07-06-2023, 06:27 AM)poVoq Wrote: Maybe the new release of Tow-boot finally fixes the black screen issues on 2020 Pinebook Pros: https://github.com/Tow-Boot/Tow-Boot/rel...022.07-006
I had been having exactly the same issue so I used Tow-boot. It seems to run fine (other than occasionally ignoring all keyboard presses) and let me select SD to boot from. Problem is it then says that it can't boot from the SD. I've tried multiple cards, same issue. I guess either there legitimately is an issue with the cards or the images, but now I'm wondering if there is something else. I can use the SD card reader to access files on the card through Manjaro, so it doesn't seem to be a hardware issue. Other than trying new cards/images, are there any other suggestions?
tow-boot has a new release 2023.07-007
I just upgraded this version on SPI with a USB key from the tow-boot boot menu
Kind regards,
Xavier Miller.
Question Can't Boot from MicroSD (What Am I Missing) falken 10 4,052 04-28-2023, 04:26 PM
Last Post: pinemouth
  How to install Ubuntu to eMMC and to install KDE (Neon) Wizzard 66 100,037 12-22-2020, 03:05 PM
Last Post: Wizzard
  Video : How to install Armbian Reforged and set it up on PineBookPro / Gaming image NicoD-SBC 0 2,790 11-23-2020, 12:09 PM
Last Post: NicoD-SBC
  Extracting a copy of SPI NOR flash contents using micro SD card and u-boot hmuller 0 2,744 09-21-2020, 11:24 AM
Last Post: hmuller
  Program SPI NOR Flash on Pinebook Pro with u-boot on micro SD Card hmuller 0 3,464 09-21-2020, 10:02 AM
Last Post: hmuller
  Citrix Receiver / ICAClient install for armhf Arwen 7 15,368 09-14-2020, 11:02 PM
Last Post: vb_linux
  How to boot Manjaro from NVME with uboot on eMMC as400 47 57,201 06-07-2020, 02:37 AM
Last Post: as400
  How to get kernel boot messages on screen on Manjaro as400 2 4,375 01-23-2020, 04:35 PM
Last Post: as400
  Dual booting Linux with ChromiumOS using "boot floppy" Wizzard 5 7,089 11-28-2019, 12:23 PM
Last Post: TDC_PBP
