07-14-2016, 05:23 AM
There are two unpopulated sets of vias for LED's on the board between the power switch and the IR socket. I was just wondering if anyone knows what they are for.
Through hole LEDs
07-14-2016, 07:23 AM
This has been discussed a while ago.
The left one is simply connected to GPIO PL7 and can be controlled by software and the other is the "Charge" status of the PMU for battery charger.
07-14-2016, 03:50 PM
(07-14-2016, 07:23 AM)martinayotte Wrote: This has been discussed a while ago. Thanks! That brings up one more, how is the charge status indicator supposed to behave?
07-15-2016, 08:04 AM
(This post was last modified: 07-15-2016, 08:05 AM by martinayotte.)
Since I don't use battery, the charger is useless for me.
But I presume that this LED is glowing while charging and will turn off when battery reach proper charge level.
07-16-2016, 07:33 PM
(07-15-2016, 08:04 AM)martinayotte Wrote: Since I don't use battery, the charger is useless for me. I have used a battery with the pine64, and the charge led doesn't work for me. I believe the PMIC chip needs configuring before it controls the LED
07-17-2016, 01:46 AM
Yes there needs to be a bit set in register 32h on the PMIC. I want to do that via pmc_init() in the ATF, unless someone has a better idea?
Come have a chat in the Pine IRC channel >>
LEDs near the Switches | victagayun | 1 | 3,056 |
10-11-2016, 05:52 AM Last Post: tllim |
