08-27-2022, 03:04 PM
Using the image from http://nycdn.netbsd.org/pub/arm/, (dd'ing to eMMC) U-boot just works, and works well.
:wq
[ SRA accepts you ]
[ SRA accepts you ]
Booting NetBSD
:wq
[ SRA accepts you ]
08-28-2022, 12:53 PM
You can use swap, but you have to halt the first boot and change rc.conf to not resize the disk. I did this before and it wasn't worth it. File-based swap is fast enough for situations where I've thought I needed it, but I don't normally do that either. I haven't had a situation where I actually need it.
sysinst does not create a boot that will work on anything but x86, and as far as I know this is intentional: the other systems vary too much. You can cook your own installation; I've done that too, but frankly I had too much trouble getting U-boot to work. Most days using the serial console is a big hassle for me. If only it was 19,200 baud... I'll keep my opinions on MBR and GPT to myself; I don't like most things that come from the x86 world.
:wq
[ SRA accepts you ]
08-30-2022, 01:23 AM
Ok, with great help of good people on #netbsd, I finally got the system booting after sysinst.
The trick is to leave enough space for binary blobs before beginning of /boot partition. Install u-boot-pinebook-pro package with pkgin and then run installboot. Read the plist file in /usr/pkg/share/u-boot/pinebook-pro/ dir and man installboot for further details. |
2nd NetBSD boot goes dark | donn | 6 | 1,986 |
02-22-2024, 03:59 AM Last Post: KC9UDX |
NetBSD 1.0 runs down battery | donn | 13 | 1,651 |
11-15-2023, 04:05 PM Last Post: KC9UDX |
NetBSD on the Pinebook Pro in August 2022 - or not? | KC9UDX | 6 | 3,828 |
08-24-2022, 01:49 AM Last Post: KC9UDX |
NetBSD and pinebook keyboard/trackpad firmware updater | mrgtwentythree | 5 | 10,014 |
05-16-2021, 07:37 PM Last Post: mrgtwentythree |
NetBSD | Der Geist der Maschine | 76 | 111,419 |
05-16-2021, 02:43 PM Last Post: mrgtwentythree |
NetBSD and USB "sound cards" | KC9UDX | 2 | 5,404 |
05-07-2021, 12:11 PM Last Post: elimark1 |
Issues Installing NetBSD on a PineBook Pro | ReleaseTheGeese | 14 | 15,227 |
01-31-2021, 11:20 AM Last Post: KC9UDX |
NetBSD -Current binaries | BronzeBeard | 8 | 11,733 |
12-31-2020, 08:38 PM Last Post: BronzeBeard |
My NetBSD on Pinebook Pro journey | KC9UDX | 11 | 18,873 |
12-06-2020, 08:26 PM Last Post: KC9UDX |
