how to install updates?
i have the software application running that states there are updates. but it just does not install any of them. when i click on "install" or "upgrade" or what that button shows, it shortly says "cancel" and thats it, nothing else happens.
i thought i could do that manually with a terminal like apk update, but i dont have any root password
so how can i install updates without all the time reinstalling the complete OS?
(04-26-2022, 11:00 AM)someGermanGuy Wrote: i have the software application running that states there are updates. but it just does not install any of them. when i click on "install" or "upgrade" or what that button shows, it shortly says "cancel" and thats it, nothing else happens.
There is a default root password which should be 147147, https://wiki.pine64.org/index.php?title=...stmarketOS
Personally, I've never had luck updating with the software center and it takes up way too much resources for doing nothing so I ended up deleting it.
147147 did not work, also my PIN does not work with sudo
how do you install updates?
  Fresh install pmos+phosh does not boot user641 1 576 10-08-2023, 04:04 AM
Last Post: user641
  Install 9999 packages AndyM 0 580 07-24-2023, 01:07 AM
Last Post: AndyM
  Can't install powersupply user641 0 522 07-18-2023, 08:09 AM
Last Post: user641
  Trying to install Mousai AndyM 0 600 06-10-2023, 08:25 AM
Last Post: AndyM
  How to install software AndyM 8 7,676 11-14-2021, 01:08 AM
Last Post: AndyM
  How do I install packages? cefre00 3 12,395 11-12-2020, 01:49 PM
Last Post: cefre00
  Unsure how to install, help needed GloriousCoffee 8 10,213 09-01-2020, 10:55 PM
Last Post: bitnick
  Latest Installer Image hangs after updates u20200719 4 5,730 07-22-2020, 11:35 AM
Last Post: u20200719
  Install And Configure PostmarketOS With Plasma Mobile dustfinger 4 8,007 06-21-2020, 09:00 AM
Last Post: dustfinger
  Does pmbootstrap install the latest image? mypine 4 6,259 02-20-2020, 01:02 PM
Last Post: mypine
