SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial)
(04-01-2022, 04:14 AM)bavay Wrote:
(04-01-2022, 04:07 AM)GreyLinux Wrote: sorry for the delayed reply work lately has been insane, I'm not sure why this is happening have you tried the udev rule with only one drive or none connected , just the Marvell Pcie connected ?
That's a good idea, I've not tried it yet, but I'll do it. So far, I've opened a bug report on the Marvell kernel driver bugzilla (see https://bugzilla.kernel.org/show_bug.cgi?id=215732). I'll comment more once I'll have tried with only one disk or even none connected to the adapter.
So after using grep on my dmesg output I do see this error, however it doesnt cause any issues with the drives. Do you have issues apart from the speeds , with accessing or writing to the drives ?
I've tried to start without any disks connected to the adapter and it behaves the same (same error message and stack trace).
Quote:Do you have issues apart from the speeds , with accessing or writing to the drives ?
No, the disks work fine (daily reads/writes, trim, smart reporting), I have not seen any weird behavior beside that the speed is lower than expected.
(04-04-2022, 02:28 AM)bavay Wrote: I've tried to start without any disks connected to the adapter and it behaves the same (same error message and stack trace).
Interesting , well hopefully your bug report will provide us with an answer to the error.
With regards to speeds I have closer to 310Mbps with the adapter ,this is with a crucial SSD, however I will be upgrading to a samsung EVO SSD tomorrow , I can report back with the speeds produced then.
  Smart TV & server storz 1 1,340 01-19-2024, 01:59 PM
Last Post: dairymilkbatman
  Home Server with RAID 1 SATA M2 SSDs runyor 7 2,484 09-26-2023, 09:14 AM
  Umbrel Server Shaeroden 0 1,340 05-04-2022, 06:14 PM
Last Post: Shaeroden
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 4,394 01-17-2021, 11:33 AM
Last Post: GreyLinux
  Tutorial:How to Configure ATS Fan control tuxd3v 26 53,314 11-06-2020, 08:56 PM
Last Post: g_t_j
  Serial Connection Tutorial: FTDI 232RL hmuller 0 3,250 10-23-2020, 11:56 AM
Last Post: hmuller
  [WIP] backup server (4 sata HDDs + ZFS) rolando 8 12,066 06-30-2020, 10:58 AM
Last Post: dml-pc
  OMV + VPN server + Pi Hole? odhinnhrafn 3 7,917 03-16-2020, 05:01 PM
Last Post: mabs
Video ARMBand an easily configured Home Media Server gabrielsr 2 6,170 07-22-2019, 04:56 AM
Last Post: stuartiannaylor
Wink Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment tuxd3v 14 24,198 06-19-2019, 04:40 AM
Last Post: Neo2018
