chatty v0.6 in Bookworm at last!
just tried xmpp on chatty, works fine for some contacts for some other encryption does not work yet
(02-05-2022, 06:54 PM)kk22 Wrote: I'm still not able to get MMS to work. Upgrading to 0.6.0 let me attempt to send MMS messages, but only SMS messages will actually be sent or received.
Did you set MMSC (or whatever it's called) in Chatty?
Cheers,
TRS-80
Protocols, not Platforms
Yes, and I was eventually able to get it to work. The missing step was that I needed to create a new APN in Settings to correspond to the APN info I was able to find online for my carrier.
The limited SMS/MMS testing I was able to do with my test SIM seemed to go well.  I switched the Pinephone to my "daily driver" SIM today.  A big thanks to kop316 and anyone else involved in the MMS project.
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,683 05-09-2024, 03:08 AM
Last Post: anonymous
  Chatty Matrix Decryption Key jojuma 2 328 02-26-2024, 12:48 PM
  Jabber with chatty user641 2 1,030 11-12-2023, 02:10 AM
Last Post: user641
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,697 08-31-2023, 12:38 PM
Last Post: vusra
  Chatty does not work after suspend mode user641 4 2,008 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  Debian bookworm security repo user641 2 1,633 02-17-2023, 01:12 AM
Last Post: user641
  beware chatty 0.7.0~rc0-1 treebeard 6 2,701 11-06-2022, 04:51 PM
Last Post: treebeard
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 4,193 09-30-2022, 08:53 PM
  Unable to send messages with chatty user641 0 797 09-07-2022, 04:35 AM
Last Post: user641
  Bookworm Satellite Navigation biketool 7 3,333 09-02-2022, 01:42 PM
Last Post: vortex
