pinephone boots to green screen after running out of space
I installed PostmarketOS sxmo on my pinephone eMMC via jumpdrive.
(The installer image from https://images.postmarketos.org/bpo/v21....0119-0539/ )
$ df -h /
Filesystem        Size  Used Avail Use% Mounted on
/dev/mapper/root  1.7G  1.6G    0 100% /
which seemed wrong to me. I would expect a Size much closer to 32G.
I installed a small number of packages then tried to clone a git repo. The cloning failed due to not enough space.
I rebooted and get a blank green screen now after the pmOS logo after entering encryption password.
Based on the df output, did I screw up the install badly somehow?
I have no data to lose on the device and would be fine reinstalling, but do I have any sane way forward from the current state? sshd is not set to run on startup and the device does not have a static IP.
To be more clear, my steps:
- dd jumpdrive img to SD card
- boot pinephone with SD card
- connected to PC and dd'd the sxmo installer img to eMMC
- booted pinephone without SD card and installed
- pmOS was running well across multiple boots
I reinstalled and df is now giving expected output.
I deleted the partitions on the eMMC (device became one block of unallocated) before dd'ing onto it via jumpdrive.
  [Not Pinephone] Phosh Autologin LienRag 11 2,235 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  How to choose which Waydroid Apps can appear on PostmaketOS Home Screen? Avisando 6 2,461 05-28-2023, 10:54 PM
Last Post: Avisando
  Boots To Shell After Dead Battery (PMOS) britelite 0 765 02-17-2023, 02:41 PM
Last Post: britelite
  Pinephone 64 PostMarketOS edition Battery Issues, Not Hardware Issue X0X0X0X0X0 1 1,444 02-11-2023, 08:19 AM
Last Post: acid andy
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 1,441 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 1 1,197 11-06-2022, 06:41 PM
Last Post: Chief
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 2,730 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  Pinephone Keyboard Utilities on postmarketOS elof 2 3,247 06-20-2022, 01:33 PM
Last Post: elof
  PinePhone, getting started totilele 1 1,509 06-15-2022, 01:56 AM
Last Post: wibble
  Bluetooth mouse paired to PinePhone POS always disconnect Peter Gamma 0 1,004 06-12-2022, 03:03 AM
Last Post: Peter Gamma
