My PinePhone does not read SD card
I bought PinePhone got it but sadly the phone is not detecting the SD card, I tried different os but but the phone always boots to preloaded plasma-mobile.
What can I do ?
Can it see the SD card after booting? Open a terminal and run lsblk. Is the card confirmed to be functional? How are you flashing? If the bootloader is mangled the phone can't boot off of it. Usually it's a problem with how the card was flashed.
(11-05-2021, 10:03 AM)Dendrocalamus64 Wrote: Can it see the SD card after booting?  Open a terminal and run lsblk.  Is the card confirmed to be functional?  How are you flashing?  If the bootloader is mangled the phone can't boot off of it.  Usually it's a problem with how the card was flashed.
ok so lsblk command gives result:
$ lsblk
NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINTS
mmcblk2      179:0    0    29G  0 disk
├─mmcblk2p1  179:1    0 213.6M  0 part /boot
└─mmcblk2p2  179:2    0  28.7G  0 part /
mmcblk2boot0 179:32  0    4M  1 disk
mmcblk2boot1 179:64  0    4M  1 disk
zram0        253:0    0  4.4G  0 disk [SWAP]
I was using balenaEtcher to flash the card.
The card seems to be fully functional at least when I access it from PC
It looks like that is a convergence edition with the 32GB eMMC and the SD card indeed isn't being assigned a device node. It should be showing up as /dev/mmcblk<something> and possible to manipulate even if it isn't flashed with a bootable system. Next thing to try is to run 'dmesg --follow' and see what messages are printed when inserting the card into the running phone. Then acquire and test some more SD cards. If none of them work, it may be a hardware problem.
(I am presuming that the MicroSD card is being inserted in the top slot as it should be - Wiki)
Related threads:
Sd card slot death?
Pinephone - Tips and Tricks - Experience and Lessons learned
According to both of these, it's possible to damage the pins in the SD card reader.
Looks like the reader is on the mainboard so it would be possible to replace that rather than the entire phone.
I appreciate the help.
OK so I have followed the instruction and run dmesg --follow
It printed bunch of logs and then stopped. There are some errors among the logs but I am not sure if they are related to the sd card issue.
Anyway then I started to insert and remove the sd card while running the phone and nothing happened. I also tried to wiggle it. and still noting.
But then I applied pressure from the top when the card contacts should be and dmesg started to print
[ 91.327692] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 91.327755] mmc0: error -22 whilst initialising SDIO card
[ 92.351857] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 92.351920] mmc0: error -22 whilst initialising SDIO card
[ 94.399533] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 94.399592] mmc0: error -22 whilst initialising SDIO card
[ 98.497900] sunxi-mmc 1c0f000.mmc: no support for card's volts
[ 98.497963] mmc0: error -22 whilst initialising SDIO card
I am going to try other cards but so far I only have 64G Sandisk
  eSIM on PinePhone just_a_q 4 2,740 Yesterday, 01:35 PM
  Pinephone boot. Richy_T 4 200 05-06-2024, 08:32 AM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 960 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 475 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 319 04-02-2024, 11:50 AM
  install iso from sd card to emmc aular 2 442 03-11-2024, 10:24 PM
  Are you using the Pinephone as your daily driver? jro 157 111,602 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,995 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 706 01-19-2024, 01:29 PM
Last Post: fxc
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 1,059 01-09-2024, 07:02 PM
Last Post: britelite
