Installing Mobian --> "Resizing file system" forever
(03-22-2021, 03:42 PM)Anna Wrote: To install Mobian on an SD card I, all I theoretically have to do is to download mobian-pinephone-phosh-20210314.img.gz, write it to the card, put the card into the phone and start it, right?
However, when I do that, the "resizing file system during initial boot" screen is there for quite a long time (30 minutes maybe) and afterwards the screen turns black (not pitch black though, the display remains switched on) and that's it.
I have used two different 64 GB cards  (a new Sandisk Extreme and and old Sandisk Ultra). I used BalenaEtcher and I tried
sudo zcat mobian-pinephone-phosh-20210314.img.gz | sudo dd of=/dev/mmcblk0 bs=1M
What am I doing wrong? Huh
If you are using Balena Etcher :
      You do not SUDO  anything.
You simply download Mobian,  then use Balena Etcher to flash your sd card.
<(You Can prep your sd card,   IF   you so desire,  format or zero wipe or whatever)>
I have been using Balena Etcher and Mobian since the first release of Mobian.
   * (actually that's all I have ever used,  -  since I purchased my first Pinebook Pro, from the first public sales,  second batch I think, Sept. 2019)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(08-31-2021, 11:59 PM)bcnaz Wrote: If you are using Balena Etcher :
Thanks! Sorry if I did not express myself clearly: I had tried "sudo zcat..." and, after that attempt failed, I tried Balena Etcher, both several times.
The solution was @dukla2000 's answer.
our Pinephone arrived about a week ago and I had the "resizing forever" issue with mobian-pinephone-phosh-2021051 yesterday. My solution was to resize it manually before inserting the SD into the computer.
Just wanted to say that the filesystem is f2fs, not ext2 as described in the Installation Instructions
For me, these commands worked:
: sudo bmaptool copy --bmap Downloads/mobian-pinephone-phosh-20210517.img.bmap Downloads/mobian-pinephone-phosh-20210517.img.gz /dev/mmcblk0
: sudo growpart /dev/mmcblk0 2
: sudo resize.f2fs /dev/mmcblk0p2
(09-09-2021, 02:42 AM)loderunner Wrote: Just wanted to say that the filesystem is f2fs, not ext2 as described in the Installation Instructions
Just wanted to say, that these are not the installation instructions for mobian which has it's own.
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 24 2,472 05-05-2024, 07:42 AM
Last Post: zetabeta
  Mobian repository status henrythemouse 16 8,974 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 154 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,072 11-22-2023, 11:46 AM
Last Post: aLoop100o
  Errors when start the system kubussz 2 609 11-21-2023, 11:07 AM
Last Post: kubussz
  System won't suspend due to suspention notification user641 6 1,500 09-24-2023, 05:47 AM
Last Post: user641
  What actions needed to keep on mobian testing user641 3 1,875 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 651 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,055 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,935 07-09-2023, 01:37 AM
Last Post: vusra
