Virtualizing Pinephone Operating Systems?
Hello all, first post after a long lurk!
I am planning to preorder a pinephone, and in preparation I would like to be able to explore the OS options so I can quickly settle on a daily driver. I am hoping to fully replace my android and this is basically the last step in my de-googling process. I do need some functionality for work however, so again, I would like to explore the available operating systems while I wait for shipping to begin.
Is anyone aware of a method of running any of the supported OSs in a virtual machine such as KVM? I tried to get iso files but could only get installer tools and .img files for the ones I was most interested in. If anyone has any insight I would very much appreciate it!
If you're on Gnome (or some other Gnome-based shell like Cinnamon or Unity), you can just download the source code, compile, and run as instructed in the README file.
You can run Phosh inside of Gnome/Cinnamon/Unity/whatever using:
SKIP_GNOME_SESSION=1 ../phoc/_build/run -E '_build/run -U' -C ./data/phoc.ini
The application menu will show apps you have on your own PC, but some of those that support libhandy will run inside of it and kind of behave like their mobile versions.
Apps without this support will simply open in a separate window like usual.
The reason is simply because Phosh is really just a Gnome shell for small touch displays.
Everything beyond that is literally the same as on a PC with a Linux distro running Gnome DE.
Edit:
In case somebody starts attacking me for helping you like last time, I'll add this page as an alternative option:
https://developer.puri.sm/Librem5/Develo.../qemu.html
However, I didn't test this method.
母語は日本語ですが、英語も喋れます(ry
If you want to sandbox it, maybe try with something like QEMU and an image of your choice? I know someone who have used this method to successfully do it in order to test a keyboard layout for squeekboard
  Pinephone boot. Richy_T 1 12 43 minutes ago
  PinePhone - boot from microSD laserpyramid 9 835 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 414 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 277 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,675 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,910 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 656 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,492 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 535 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,778 12-22-2023, 03:44 PM
