PinePhone already setup?
I just received my PinePhone and I'm very excited to try it out! But after removing the tap between the battery and connector and booting up for the first time, I was taken to a lock screen. Swiping up takes me to a screen for entering a passcode. I was not taken through a first-run setup to create a user and I don't know what passcode I'm supposed to use.
Did I miss some communication about the phones being preset up and having a default code or do I need to reset the phone somehow? If so, any advice on how to do that would be appreciated.
The default Pin for Manjaro is: 1 2 3 4 5 6
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
@bcnaz Thanks alot!
Hi, I had a similar experience -
 after it started up did the navigation buttons appear or did you have to update or do something to get them to appear?
(02-27-2021, 10:27 PM)DonF22 Wrote: Hi, I had a similar experience -
I have just got my Pinephone Beta Edition and it has taken me through creation of user etc.  Now it asks for a PIN and 123456 does not work.  How do I progress?
Chris
I can now answer my own question...
On initial boot, I am asked to create a user with a password.  I did just that.  It then wouldn't let me continue until I entered a PIN.  It was only when I booted from an SD card image and repeated the process that I realised that Password and PIN were the same thing and that I should only have entered digits (numbers) originally (yes. It does tell you first time around).  Since my password happened to contain numbers I could unlock by just entering those.
Now happily playing
Chris
  Pinephone boot. Richy_T 4 112 05-06-2024, 08:32 AM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 886 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 443 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 295 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 111,011 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,945 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 674 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,546 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 552 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,805 12-22-2023, 03:44 PM
