Axolotl on PinePhone / Mobian
i said elsewhere, but maybe repeat.
i manage to install and register signal on waydroid x86_64 on a laptop. however, no camera support, so it means no linking to other apps, like signal-desktop. waydroid also requires wayland support, which may not be straitforward.
I have signal-desktop on my PC (RockPro64) and all my PinePhone installs. Compile once on the RockPro for aarch64 and install everywhere else :-)
Thank you both for your replies! Smile
I think I will also try to use Signal desktop if I have a working ever Linux smartphone again.
(My both PinePhones went bad and are just annoying electronic waste now I'm afraid, so Axolotl currently doesn't really matter for me anymore...)
Again, thanks!
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
...and it works again! Texts are visible here since yesterdays regular Mobian updates - It's seems some component/framework(?) which was used by Axolotl in the background was buggy/wasn't compatible anymore... and is fixed now. Smile
...it's somehow wierd (but nice! Wink ) that Axolotl on Mobian STILL works here... (last version is from Oct 27 2022, I waiting for a critical change on the Signal infrastructure that finally kills Axolotl any day, but so far it still works! Smile )
how do i remove nanu-c axsolotl,  now that there is a deb package?
ezik
(03-22-2023, 12:05 AM)shulamy Wrote: how do i remove nanu-c axsolotl,  now that there is a deb package?
ezik
sudo apt-get purge axolotl
# if previous does not work, don't use as first option
sudo dpkg purge axolotl
you could use "aptitude" or other software manager program as well.
i don't recommend auto-updating for beta products like pinephone (pro).
but
"E: Unable to locate package axolotl"
  the app exist in the pinephone but doesn't work properly
 ezik
dpkg can not find axolotl package as well
(with the command sudo dpkg --purge axolotl)
ezik
(03-22-2023, 04:58 AM)shulamy Wrote: but
 ezik
ezik
now i stat to have feeling that there is multiple overlapping installation, like flatpak, appimage, snap or even compiled from source. try to uninstall all of them, but given precise instructions might be inaccurate.
there was tow but both were from deb packge "axolotl_1.6.0-1_arm64.deb"
ezik
i tried (again) with the "software" gui an this time it removed the second axsolotl
ezik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 24 2,417 Yesterday, 07:42 AM
Last Post: zetabeta
  Mobian repository status henrythemouse 16 8,944 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 150 03-18-2024, 08:54 PM
Last Post: penguins_rule
  unofficial kali linux for pinephone help needed pinesmell 5 3,692 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,067 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,865 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 648 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,042 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,933 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 647 07-05-2023, 03:57 AM
Last Post: paulcarton
