09-08-2020, 03:38 PM
Pinephone Community Edition doesn't boot from SD-Card Only Red LED
09-09-2020, 09:33 AM
(09-08-2020, 03:38 PM)ThrillGates Wrote:Aren't they one and the same in this case, or am I looking in the wrong place? (https://ci.ubports.com/job/rootfs/job/ro...stemimage/)(09-08-2020, 09:52 AM)robthebold Wrote: September 6 build (#78) boots on 3GB phones
09-09-2020, 03:30 PM
(09-08-2020, 03:38 PM)ThrillGates Wrote:(09-08-2020, 09:52 AM)robthebold Wrote: September 6 build (#78) boots on 3GB phones Are you referring to Mobian "from Sep 5" works ? On Mobian the Sep 5 release is considered "stable" while the "nightly's" are considered cutting edge or testing. They are listed in the same list on the download page, but certain ones are considered "stable" I do not know if ubports has some that are considered as "stable", they may have some also..? ubports does also do nightly builds like Mobian.
09-09-2020, 06:44 PM
(09-09-2020, 03:30 PM)bcnaz Wrote:(09-08-2020, 03:38 PM)ThrillGates Wrote:(09-08-2020, 09:52 AM)robthebold Wrote: September 6 build (#78) boots on 3GB phones Yes. I'm taking the stable terminology from Mobian and trying to make clear that you don't need a nightly build to boot on a 3GB phone. AFAIK the ability to boot on 3GB phones is what makes the Sep 5 build the latest stable one. That being said, we need people to use the nightly builds. Thanks for your efforts. To your other point, stable/test builds in UBports are controlled with the options found at System Settings > Updates > Update Settings. I enabled "Release Candidate" to update to OTA-13. At some point, OTA-13 will be promoted to "stable" and be used for the nightly builds. I guess this means that the nightly UBports builds are stable builds, too. |
Pinephone won't boot. | spha | 13 | 3,029 |
1 hour ago Last Post: Richy_T |
Pinephone boot. | Richy_T | 5 | 227 |
7 hours ago Last Post: Richy_T |
eSIM on PinePhone | just_a_q | 4 | 2,762 |
Yesterday, 01:35 PM Last Post: Kevin Kofler |
PinePhone - boot from microSD | laserpyramid | 9 | 966 |
05-03-2024, 10:09 AM Last Post: laserpyramid |
pinephone virtual keyboard | aular | 4 | 478 |
04-10-2024, 03:45 PM Last Post: aular |
PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging | dorkydev | 1 | 324 |
04-02-2024, 11:50 AM Last Post: Kevin Kofler |
install iso from sd card to emmc | aular | 2 | 444 |
03-11-2024, 10:24 PM Last Post: tllim |
Are you using the Pinephone as your daily driver? | jro | 157 | 111,690 |
02-18-2024, 11:33 PM Last Post: aular |
2020 PinePhone Manjaro CE EU for sale, name your price | astrojuanlu | 7 | 1,998 |
02-14-2024, 04:51 PM Last Post: astrojuanlu |
pinephone is not bootble for the box. | ijij | 1 | 712 |
01-19-2024, 01:29 PM Last Post: fxc |
