Mobian screen dims
(06-27-2020, 05:26 AM)a-wai Wrote: Ok thanks! When you have time, could you please read through https://gitlab.com/mobian1/issues/-/issues/3 and replicate the measurements other people did?
(basically, every in_proximity_* files, both with the stock and custom kernel mentioned in the thread)
This would be helpful in trying to understand what's going on here (no hurry, it won't be solved overnight anyway).
Okay will do thanks.
I have exactly the same issue with my BH PinePhone trying to run the latest Mobian.
The login screen works perfectly, but then it turns grey. I can then press the power button a couple of times and use the login screen again, which is correctly drawn on the screen, but then as soon as I unlock, it's a grey screen again.
I obviously haven't been able to setup a WiFi connection yet for it - does the USB connection allow for a SSH connection on a plain Mobian image? I cannot get to a point where I can install anything.
Any help would be greatly appreciated.
Have a look at this thread: https://forum.pine64.org/showthread.php?tid=9694
I replaced my screen recently and forgot to move the "divider" to the new one at first.
After swapping them the issue is gone.
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 21 2,177 Yesterday, 09:27 AM
Last Post: anonymous
  Mobian repository status henrythemouse 16 8,833 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 140 03-18-2024, 08:54 PM
Last Post: penguins_rule
  Screen auto-rotation sensitivity mdk 0 278 12-26-2023, 06:08 AM
Last Post: mdk
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,022 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,845 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 643 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,951 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,914 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 640 07-05-2023, 03:57 AM
Last Post: paulcarton
