openSUSE for Pinephone
#21
This is a nice build! Phosh is is very fast and the pre-installed applications work well. I have a few questions though.
1: how do I resize applications that are too large for the screen? The trick mentioned on the Mobian wiki doesn't work.
2: what is the default root password? I was asked for it when I tried to change time zone settings; I had to "sudo passwd root".
3: how do I launch the YaST modules? After I input the root password, nothing opens.
Thanks for the hard work!
New version, the most remarkable improvements are ringtone working, battery life improved, modem wake-up after suspend, unlock simcard pin on settings and gnome-usage package installed
- v0.0.2-2 (28 Jul 2020)
    New Gnome Control Center with patches for Mobile
    New Gnome Contacts
    New Gnome Usage with patches to fit
    Added gtherm package
    Improvement on suspend tweaks
    Update Calls app with patches for audio
    Update Phosh to 0.4.2
    Update Phoc to 0.4.1
    Update Wys to user as a user service
    Change dtsi to set audio-card-name as Pinephone
    Update Feedbackd theme
(07-28-2020, 06:18 PM)Hyz Wrote: This is a nice build!  Phosh is is very fast and the pre-installed applications work well.  I have a few questions though.
1 - Resize apps with Phosh are not posible i think, maybe using cli but for now i didn't find how to do it.
2 - Root does not have any password but you can use pine / 1234 and this user is on sudoers file, so you can do sudo su and add a password for root.
3 - What do you mean with launch yast modules?
(07-30-2020, 01:50 AM)Alefnode Wrote: 1 - Resize apps with Phosh are not posible i think, maybe using cli but for now i didn't find how to do it.
Mobian has it working, here is their documentation on the subject; unfortunately, the command specified here doesn't work on openSUSE.
(07-30-2020, 01:50 AM)Alefnode Wrote: 2 - Root does not have any password but you can use pine / 1234 and this user is on sudoers file, so you can do sudo su and add a password for root.
Thank you!
(07-30-2020, 01:50 AM)Alefnode Wrote: 3 - What do you mean with launch yast modules?
.png   20200730_18h59m39s_grim.png (Size: 130.08 KB / Downloads: 568)
(ignore the terminal) these launchers popped up in the application menu after an update, but none of them actually launch anything.
Quote:(ignore the terminal) these launchers popped up in the application menu after an update, but none of them actually launch anything.
I recommend to update using no-rommends package, because not all software are already adapted for small screens.
New version with some changes:
http://images.alefnode.com/openSUSE-Pine....0.2-3.img
## v0.0.2-3 (31 Aug 2020)
New packages and working camera app.
**Implemented enhancements:**
- Installed new Camera package
- Update gnome-shell to 3.36.5
- Update kernel to improve battery time
- Update Phosh to 0.4.3
- Update Phoc to 0.4.2
**Working:**
- Calls (Auto-switch audio profiles)
- SMS
- Mobile Data
- WiFi
- Front Camera (laggy)
- Back Camera (laggy)
- Touchscreen
- Brightness
- Sound & Mic
- Volume keys
- Proximity sensor
**Not Working:**
- Bluetooth
- Accelerometer
- Jack
Now all images are generated as a contrib project in opensuse build service.
https://download.opensuse.org/repositori...ne/images/
Firstly, thanks for making these images.
I have a question: Is it not possibly to resize the partition after writing the image to sd?
When I resize the second partition, it wont boot from sd (pinephone starts from mmc), without resizing it, it works flawlessly.
I'm using the method described on the pine64 wiki (here: https://wiki.pine64.org/index.php?title=...g_computer)
Do I something wrong or is resizing simply not possible yet?
Don't use that method use this:
# HACK: Auto-resize FS
check_root_partition=$(mount | grep " / " | awk NR==1 | awk '{print $1}')
if [[ "$check_root_partition" == "/dev/mmcblk0p2" ]]; then
sgdisk -e /dev/mmcblk0
sgdisk -d 2 /dev/mmcblk0
sgdisk -N 2 /dev/mmcblk0
partprobe /dev/mmcblk0
resize2fs /dev/mmcblk0p2
fi
This is added on last image for auto-resize in first boot
Last image published.
2020.09.25
- Auto-resize FS in first boot
- Upgraded Chatty
- Added some fonts to improve UX in terminal and System
- Fix a problem with Camera
## 2020.10.14
New packages with responsive UI and new keyboard
- Updated PHOSH to 0.4.5 (Fixed volume bar in quick settings)
- Updated PHOC to 0.4.3
- Updated Squeekboard to 1.9.3 (now with terminal controls)
- Adapted gnome-software to work in small screens (a.k.a gnome-software-phosh)
- Added Flashlight app (a.k.a Torch)
- Adapted u-boot to work with openSUSE standar scheme
- New Kernel 5.8 compiled in OBS (openSUSE build service)
- Now openSUSE image works with initramfs
- Added Nemo as default filemanager
- Updated pinephone-helpers with new udev rules
## 2020.10.05
Fix some problem with new pipeline (now we are using OBS from openSUSE)
- Update PHOSH to 0.4.4
- Update feedbackd to latest commit
- Update purple-mms-sms package to 0.1.8
- Update Tumbleweed to 20201004
Just tried this latest OpenSUSE image - looking really impressive, great work!
  Using Signal on PinePhone in mid-2023? dante404 47 14,743 05-03-2024, 02:19 AM
Last Post: dragonhospital
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 25,856 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 4,401 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 575 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,570 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 25,366 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,249 11-23-2023, 01:06 AM
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,099 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,570 10-24-2023, 08:57 AM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,627 10-18-2023, 08:37 AM
Last Post: luppivega
