openSUSE for Pinephone
#31
Now i am working in features like improving battery and bluetooth.
Moreover for next release i think also we can have improvement in FPS (from megi's patches) and new kernel version (5.9)
Looking forward into testing this... let's hope my PinePhone arrives soon so I can start testing around.
I have a couple question about this port, though:
-Which software components are non-FOSS?
-Is YaST included (or at least the software management tools)?
-How is the battery life doing right now?
(11-04-2020, 01:39 PM)andresbs Wrote: Looking forward into testing this... let's hope my PinePhone arrives soon so I can start testing around.
For the first question, all software components arre FOSS, then you can install everything with "zypper install" or whatever command you use with opensuse OS, Yast2 gui are not well adapted for mobile UI so it disabled by default, you can install it and test it if you want.
Battery life i think is worst part for now, maybe 1 working day without using it a lot, maybe 5-6 hours using it continuosly.
## 2020.16.11
Add bootsplash for boot and shutdown
**Implemented enhancements:**
- Add bootsplash
- Fix kernel start (laggy bug)
- Fix audio problems in calls
- Added gnome-initial-setup to add language to your on-screen keyboard
- Fix problem changing between on-screen keyboard and emoji keyboard
- Change Pinhole for Megapixels for camera app
- Patched kernel with fixes for brightness
- Fix problem with modem in last release
- Now bluetooth are working correctly
**Working:**
- Calls (Auto-switch audio profiles)
- SMS
- Mobile Data
- WiFi
- Front Camera (laggy)
- Back Camera (laggy)
- Touchscreen
- Brightness
- Sound & Mic
- Volume keys
- Proximity sensor
- Jack
- Bluetooth
**Not Working:**
- Accelerometer
- GPS
Many thanks for the new version ## 2020.16.11
After flashing to a card and reparing the wrong GPT backup position, the system does boot with the fantastic animal logo Wink
For unlocking with "1234" a special keyboard does appear, but afterwards I could not get any keyboard and therefore it was not possible to enter the password for WiFi etc.
Any tricks to solve that problem?
Question
Could anyone answer some questions I have regarding the openSUSE images?
  1. What is the difference between the pinephone.aarch64.raw.xz image and the pinephone.aarch64-2020.11.16-Build9.3.raw.xz one?
  2. Considering they aren't disc image files, do I have to modify them in some way so I can flash them?
  3. Why is the nightly image page no longer available?
Appreciate any info you can share.
Do anyone know if Anbox can be installed/works on openSUSE ?
With latest image "openSUSE-Tumbleweed-ARM-PHOSH-pinephone.aarch64.raw" from 2020-11-18 the problem that no keyboard pops up when input is required still persists.
Am I the only idiot trying to get OpenSuse running?
Quote:Am I the only idiot trying to get OpenSuse running?
So it is... Angel
So it is... Angel
No I have run opensuse. Didn't see same problems although I used openSUSE-Tumbleweed-ARM-PHOSH-pinephone.aarch64-2020.10.25-Build5.1.raw
I am also burning these images using DD, win32diskimager, and etcher depending on where I am at and what OS I am booted into. And if I feel like seeing a 'kids' ui.
No issues with input on my side.
  Using Signal on PinePhone in mid-2023? dante404 47 15,944 05-03-2024, 02:19 AM
Last Post: dragonhospital
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 26,488 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 4,715 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 689 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,700 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 26,226 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,430 11-23-2023, 01:06 AM
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,189 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,782 10-24-2023, 08:57 AM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,758 10-18-2023, 08:37 AM
Last Post: luppivega
