Got Vivaldi Working on Arch!
I got Vivaldi to run under Arch, and probably the same trick would work for Chrome (which is under Vivaldi).
1. In the AUR there is a 64-bit Arm Vivaldi snapshot Download it
2. Unpack the archive and do an install like you would anything else from AUR
3. There were 2 or 3 things I had to add using pacman (in fact, I had to add fakeroot to get the packaging to work). Everything was there, just pacman -S xxxx
4. Do the install.
Now you will have a problem. Vivaldi is there but won't run. Here's why. GDK_BACKEND is set to wayland. It needs to be set to x11. You can edit the launcher or the Vivaldi script or from CLI:
GDK_BACKEND=x11 vivaldi-stable
Seems to mostly work. The interface is a bit clipped. Setting it to native window (restart required) helped I think. Moving the address bar to the bottom helped a lot.
Woo hoo!
Update: ALT+F10 maximizes the window which cleans up most of the issues.
It's in manjaros aur as an arm build too, works perfectly
A few notes. GDK_BACKEND is also the key to get emacs to run in the GUI.
binutils should be installed before the buildpkg step, but if you don't you just get a warning.
If you find the desktop files in /usr/share you can change
Exec=xxxx
to
Exec=env GDK_BACKEND=x11 xxxx
To make a shortcut like Vivaldi or emacs run properly.
(09-12-2020, 09:09 PM)wd5gnr Wrote: I got Vivaldi to run under Arch, and probably the same trick would work for Chrome (which is under Vivaldi).
4. Do the install.
Woo hoo!
hi,
I am currently running arch from the SD card still but all browsers are extremely sluggish:
epiphany is the default and I notice it uses multiple cores (since in top it gets 140%)
Installed midori, which is slightly faster.
but all load pages in 5-10 seconds or slower.
Is that just a system thing at the moment?
  Angelfish not working after installing latest image via SD catd PTCruiser 0 107 05-21-2024, 06:34 PM
Last Post: PTCruiser
  Working OS on pinetab RISC-V? user641 3 1,065 12-13-2023, 08:11 AM
  Arch Linux (danctnix) virtual keyboard layout change cudo 0 842 09-27-2023, 12:19 PM
Last Post: cudo
  Udemy not working on pinetab2 (danctnix) jbreese 3 1,264 06-13-2023, 11:34 AM
Last Post: jbreese
  Arch Linux ARM on PineTab 1 Danct12 25 30,583 06-10-2023, 05:33 PM
Last Post: fxc
Video Does DactNix Arch Linux support my use case? BlueGalaxy 22 6,916 05-18-2023, 03:45 AM
  Important apps stopped working yurievitch 2 4,603 07-14-2021, 11:43 PM
Last Post: LisaFord
  Arch, Plasma desktop and wayland peperjohnny 49 61,648 06-10-2021, 08:31 AM
Last Post: peperjohnny
  Anyone been able to get a working GloDroid img on SD? tophneal 34 38,947 06-01-2021, 08:46 AM
  Arch and ZRam wd5gnr 4 8,588 12-03-2020, 04:37 AM
Last Post: tomoqv
