I have a 2GB version with wifi, and I've gotten remixos, android, and ubuntu to boot, but I'm having severe lag and/or "not responding" popups on all OSs and all programs. I've tested my SD card and it's fine, I get 9MB/s writes and 30MB/s reads and no errors. so far remix OS is the worst performance, and I was about to try debian instead of ubuntu but now files.pine64.org is down.
I'm using a 2A wall charger and have tried a few cables, but my understand is that if it boots that shouldn't be a problem.
what do I need to look at to figure out what's going on?
Same thing here.
I using the power cables that i've got from PINE64.
I didn't test my sd card.
In my case, the led keeps beeing red. I can't have it green.
What about you?
(04-24-2016, 02:15 PM)octopus Wrote: Same thing here.
What about you?
The red led should be red and just indicates power on, so if you wait for it to become green, well, i wouldn't hold my breath for it.
Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
the early boards had green LEDs, and the "final" boards have red.
after letting it sit overnight on remixos a few play store things updated and it seems to have gotten a lot better, mostly usable. my fire phone with CM11 on it and my Ouya are still far more snappy, so it still not what I think it could be.
the card test program on the wiki shows the speed as it tests the card.
