06-12-2020, 05:32 PM
I saw a phosh anx and plasma mr1235 demo image on the PmOS site. I didn't mess with the mr1235 one, cause I prefer phosh, but I tried the phosh anx images. It worked like a lot of the previous post-March phosh images haven't for me, but it has no network in it. Even rfkill only showed bluetooth.
What does the anx version do differently? Or is it a version made for someone specifically? Or is it something really obvious and I'm being stupid?
Thanks for anyone who can scratch this curiosity itch!
It's a build with a different kernel that has a WIP driver for the anx7688 usb-c controller but doesn't have all other functionality enabled, it's not useful for general use.
yeah I've noticed this issue, I'm looking into a fix. the current brightness is set in the kernel dtb so not easy to manually change. main issue is that autobrightness is behaving very broken.
The issue is that brightness is not linear, and some slight manufacturing difference like the specific voltage drop of the leds will cause the point where the screen cuts off to be on different values, due to the nonlinearity of it it also means that the "dark" levels are very close together, so giving the cut-off point some margin for manufacturing differences will mean that for some people the lowest brightness setting is way brighter.
your display can definetly be as dark as any other phone, it's just that the current pmos config is calibrated to my specific braveheart and that causes issues for some people, we still need to figure out how to do some sort of calibration for that.
