PinePhone RTL8723CS automatic test fail and WiFi problem
I run automated tests RTL8723CS is failing.
https://wiki.pine64.org/index.php/PinePhone
If RTL8723CS is failing:
"make sure there is Wifi router around 5 meter area when perform this test, the Wifi test function sniff for SSID to determine test result during autotest. The Wifi can fail if the battery power is too low. "
I tried with battery full and charger on but still automatic tests fail and there should be Wifi signals around.
And I have not got WiFi working with Ubports or Manjaro Alpha3.
Any one else having this problem?
Any ideas how to get it to work?
Or is the HW just faulty?
(02-13-2020, 05:58 AM)surfingtux Wrote: I run automated tests RTL8723CS is failing.
I think I remember someone else with the same problem got it to work by flicking the privacy switches from off to on and back again, YMMV.
(02-13-2020, 04:10 PM)pjsf Wrote: I think I remember someone else with the same problem got it to work by flicking the privacy switches from off to on and back again, YMMV.
Earlier I had tried once to flick switches on/off and tried also to run tests when switch is off.
Now I tried multiple times but no success. Sad
Thanks for the tip. Maybe this might still help someone else.
My PinePhone failed the test for the RTL8723CS at first but after being plugged in and charging for about an hour I tried it again and now it passes. Still fails the EG25 test so I will continue to look into that.
PinePhone BraveHeart Edition
Pinephone Convergence
PineTab
RockPro64
(02-19-2020, 12:11 AM)publiclewdness Wrote: My PinePhone failed the test for the RTL8723CS at first but after being plugged in and charging for about an hour I tried it again and now it passes. Still fails the EG25 test so I will continue to look into that.
For EG25:
Do you have sim card inserted?
https://wiki.pine64.org/index.php/PinePh...quirements
and
discussion around that issue:
https://forum.pine64.org/showthread.php?tid=8991
  Pinephone won't boot. spha 13 3,423 05-15-2024, 10:31 PM
Last Post: Richy_T
  Pinephone boot. Richy_T 5 377 05-15-2024, 03:35 PM
Last Post: Richy_T
  eSIM on PinePhone just_a_q 4 2,921 05-14-2024, 01:35 PM
Exclamation No wIfI after Mobian update crakabeats 4 2,374 05-10-2024, 06:45 AM
Last Post: 98cwitr
  PinePhone - boot from microSD laserpyramid 9 1,186 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 595 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 406 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 114,080 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 2,181 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 800 01-19-2024, 01:29 PM
Last Post: fxc
