10-16-2018, 12:59 PM
I have a rockpro64 with bionic-minimal-rockpro64-0.7.10-1072-armhf.img installed on a sd card.
It runs just fine until I tried to install a desktop.
I ran /usr/local/sbin/install_desktop.sh mate and it installed a gazilion of packages.
After reboot I just get a cursor on a blank screen. After investigating the logfile ~/.local/share/xorg/Xorg.0.log it says:
[ 2609.954] (EE) AIGLX error: dlopen of /usr/lib/arm-linux-gnueabihf/dri/armsoc_dri.so failed
(/usr/lib/arm-linux-gnueabihf/dri/armsoc_dri.so: cannot open shared object file: No such file or directory)
[ 2609.954] (EE) AIGLX: reverting to software rendering
[ 2610.034] (II) IGLX: enabled GLX_MESA_copy_sub_buffer
[ 2610.037] (II) IGLX: Loaded and initialized swrast
[ 2610.037] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 2610.038] (II) ARMSOC(0): Setting screen physical size to 508 x 285
[ 2610.070] (EE) ARMSOCPrepareAccess: Failed to map buffer
I cant find the file armsoc_dri.so anyware. Any tips?
