0.7.9 Linux release from ayufan
Oh, Ubuntu. In Debian I can't even find out what libglvnd-dev is. But I just built Firefox 61 which uses GTK 3 (dev).
This is the information I have for the package:
Package: libglvnd-dev (1.0.0+git20180308-3)
Vendor neutral GL dispatch library -- development files
This is an implementation of the vendor-neutral dispatch layer for arbitrating OpenGL API calls between multiple vendors on a per-screen basis.
Thanks for the tip I will try out the debian images after work today.
Also does the onboard sound work out of the box for others using Ubuntu and or Debian?
(08-05-2018, 02:37 PM)ab1jx Wrote: Also does the onboard sound work out of the box for others using Ubuntu and or Debian?
Sound I'd like to find out about.  I can't make my HDMI sound work but I didn't try very hard.  https://forum.pine64.org/showthread.php?...4#pid39414 I have a good USB sound card I can use, didn't worry about it..
"onboard"?  what's that?  The choices I saw were HDMI, I2C, SPDIF.  Onboard sound on a Raspberry Pi is done with PWM, that could maybe be done here using GPIO pins.  I don't know what's fed to the A/V jack.
Rock64pro HDMI sound works I hear.
Try "alsactl init" then "aplay -l" on a command line.
I have been trying to get sound out of the headphone jack but selecting this does not produce sound when playing music or videos, but a USB soundcard works well.
The schematic page 17 shows this audio circuitry but I don't know how you access it from software.
(08-06-2018, 10:24 AM)nislaco23 Wrote: I have been trying to get sound out of the headphone jack but selecting this does not produce sound when playing music or videos, but a USB soundcard works well.
I have not been able to get anything out of the headphone jack, but have no issues through HDMI. (My sound demands are Noddy - if I can hear an mp3 play I am happy!)
There is sound here (Vestel 22L1333G TV/monitor, LXDE image), but it plays back several times faster than it should, i.e. at a much higher sample rate. (The www.audiocheck.net site contains a lot of interesting sounds that I used to test this.)
(08-07-2018, 03:41 AM)lucho Wrote: There is sound here (Vestel 22L1333G TV/monitor, LXDE image), but it plays back several times faster than it should, i.e. at a much higher sample rate. (The www.audiocheck.net site contains a lot of interesting sounds that I used to test this.)
This is a known issue with pulseaudio with the 4.4.132-1075 kernel that is default in the 0.7.9 Ayufan release.
You can check your kernel version with
uname -a
You can upgrade your kernel with
sudo apt-get update
sudo apt-get install linux-image-4.4.132-1083-rockchip-ayufan-gfd3f12ca5fae
and reboot
#19
I've installed Bionic LXDE, but I'm not having any success getting it to autologin. Any suggestions?
sudo vi /etc/lightdm/lightdm-gtk-greeter.conf.d/lightdm.conf
Added the following lines:
[SeatDefaults]
greeter-session=lightdm-greeter
greeter-hide-users=true
session-wrapper=/etc/X11/Xsession
autologin-user=rock64
Upon reboot, it still requests login. I've tried several different variations of the above file. I've also tried moving lightdm.conf directly into the /etc/lightdm folder.
I'm thinking that lightdm isn't looking in this directory (or perhaps it isn't functioning properly) because the desktop background specified in the same folder in 99_xxx_rock64.conf isn't loading either.
#20
If I do cat /proc/asound/cards I see:
 0 [HDMI           ]: HDMI - HDMI
                      HDMI
 1 [I2S            ]: I2S - I2S
                      I2S
 2 [SPDIF          ]: SPDIF - SPDIF
                      SPDIF
I'm guessing the AV jack is on the I2S because the other two are digital output.  And maybe the amp/driver chip is connected to the I2S bus.  Haven't tried it.
If I type alsamixergui on a command line I see this message to its stderr: "No mixer elems found".
I can do ls /dev/snd and see stuff in there, but there's no /dev/dsp
I'm trying to get HDMI sound working, at this point about the same troubleshooting steps.  This could all be missing drivers.  Audacity shows these device choices:
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 797 03-25-2024, 12:12 PM
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 993 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,530 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 2,399 04-23-2023, 01:32 PM
Last Post: diederik
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,129 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  RockPro64 linux console video mode callegar 0 935 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 8,594 04-30-2022, 03:57 PM
Last Post: TRS-80
  Armbian 22.02 Release Announcement TRS-80 0 1,216 02-28-2022, 05:08 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 4,533 01-03-2022, 10:32 AM
Last Post: whitecat23
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 1,509 07-24-2021, 09:46 PM
Last Post: Mentaluproar
