I am pondering this and am wondering if anyone has tried any of the dedicated offrngs on a Rock64. Both ClearOS and IPFire have Arm builds, but I have no idea if they work with the R64. Has anyone tried those out or any similar offerings?
Thank you in advance.
Sent from my SM-T537V using Tapatalk
i think there is [was?] a centos for pine64 but not sure of rock64. but to be honest the 1st thing that popped into my head was a concern that rock64 could be a bottleneck for the whole local network depending on what activity goes on in an average 24hr period. so, why the rock64 as firewall?
I will order something and test it out. Regarding why, well, my home router is very old and needs an upgrade and so why not?
I will thoroughly test the R64 implementation prior to using it in production and so hopefully will identify any issues.
My near term plan is to test out the ipfire image on the rock as is. If it passes that smoke test then I will look to add additional accessories including a dedicated Rock64 for the project.
Sent from my XT1254 using Tapatalk
So you have got me thinking more about this. Thank you. To be honest part of the goal was to get some web filters going and it just seems like the Rock would not be good for this.
Yes, it can do a basic firewall with the tools that you suggest, but it seems that the more full featured options require an x86 or equivalent.
