Imroved Backlight Brightness Levels
I was poking around in the device tree this evening and I noticed the PWM values for the backlight aren't the full range. With this patch, the screen is more comfortable to use at night.
You'll need to follow the instructions in section 1.3 & 1.4 of the WiFi driver guide. If you've already got your WiFi driver working, just apply the patch, recompile and update the DTB.
.txt   pinetab2-Use-better-brightness-PWM-ramp.patch.txt (Size: 2.67 KB / Downloads: 125)
