Booting NetBSD
I managed to install NetBSD on eMMC by booting from an SD card with 9.3 arm64.img and running sysinst.
Now have trouble booting up the installed system. Tow-Boot on SPI complains
"Wrong image format for "source" command."
"Can't get kernel image!"
I reinstalled kernel just to be sure
install -o root -g wheel -m 555 netbsd-GENERIC64 /netbsd
and wrote u-boot into boot sector
dd if=/usr/pkg/share/u-boot/rksd_loader.img of=/dev/rld0 seek=64 conv=sync
Also copied everything in /boot of the SD card to /boot on eMMC.
Still no luck, the system won't boot.
I don't know anything about Tow-boot, but it might be Linux-specific.
You will probably have to replace Tow-boot. At this point, I would just zero the SPI ram. I have NetBSD working with what must be the U-boot from the "Debian Desktop" install that originally came with my first PBP.
According to the NetBSD ARM mailing list, we should get bootable images (again) soon, which will come with a working U-boot. When that happens, it'll be here http://nycdn.netbsd.org/pub/arm/netbsd-9...m-aarch64/
:wq
[ SRA accepts you ]
Everyone wants me to quit using NetBSD
(08-23-2022, 05:14 AM)KC9UDX Wrote: I don't know anything about Tow-boot, but it might be Linux-specific.
There already are generic bootable images for evbarm, don't really know what do we benefit from a pbp specific image.
The main problem here is to make a newly installed system to boot after sysinst. I don't think an image is going to help here.
ps: zeroing SPI will render laptop unbootable at all.
The prebuilt images boot, and you can make a bootable system from them. I've done it (in the past).
Isn't SPI all zeroes from the factory?
:wq
[ SRA accepts you ]
This is correct
(08-23-2022, 05:14 AM)KC9UDX Wrote: According to the NetBSD ARM mailing list, we should get bootable images (again) soon, which will come with a working U-boot.  When that happens, it'll be here http://nycdn.netbsd.org/pub/arm/netbsd-9...m-aarch64/
The eagle has landed.
(08-24-2022, 02:27 PM)KC9UDX Wrote: The prebuilt images boot, and you can make a bootable system from them.  I've done it (in the past).
How exactly did you do it?
I installed u-boot-pinebook-pro from pkgsrc, tried to flash /dev/spiflash0 but get error "Device not configured". Then tried to flash /dev/rld0d and got and unbootable laptop (Wrong image format, can't get kernel image!)
I am talking about newly installed system, with sysinst, not a dd'ed img to eMMC.
Ok, I played with u-boot parameters a little and figured it out.
You have to pass these lines to u-boot console to boot from eMMC:
setenv bootargs root=ld0a
setenv kernel netbsd.ub
setenv fdtfile dtb/rk3399-pinebook-pro.dtb
boot
I dd'd the image. Originally I had to overwrite U-boot with one from Linux, but at some point the NetBSD images just started booting. But I've heard that the latest one does not. So your solution is probably the only good one at the moment. Hopefully this weekend I'll get time to play with this.
:wq
[ SRA accepts you ]
We can automate this thing a little by creating u-boot config file, but it will still boot the kernel from the SD card, only root fs will be from the new system:
1) Write a file myscript.txt in /boot on SD card
setenv kernel_addr 0x200000
setenv bootargs "root=ld0a console=fb"
2) Make an image. mkubootimage is located in /usr/src/tools. If not, get and unpack src.tar.gz set.
2.1) Remove everything in /boot on SD card, except for "efi" directory.
mkubootimage -A arm64 -C none -O netbsd -T script -n PBP myscript.txt boot.scr
3) reboot with SD card installed, root fs should be on ld0 now, not on ld1.
I still struggle to install the netbsd provided u-boot from pkgsrc to either SPI or eMMC.
/dev/spiflash0 is "Device not configured" on all kernels I've tried.
Tried flashrom on Linux, says that rkspi_loader.img is too small.
dd'ing img to /dev/ld0d gives no result.
  2nd NetBSD boot goes dark donn 6 2,202 02-22-2024, 03:59 AM
  NetBSD 1.0 runs down battery donn 13 1,822 11-15-2023, 04:05 PM
  NetBSD on the Pinebook Pro in August 2022 - or not? KC9UDX 6 3,947 08-24-2022, 01:49 AM
  NetBSD and pinebook keyboard/trackpad firmware updater mrgtwentythree 5 10,091 05-16-2021, 07:37 PM
Last Post: mrgtwentythree
  NetBSD Der Geist der Maschine 76 112,448 05-16-2021, 02:43 PM
Music NetBSD and USB "sound cards" KC9UDX 2 5,495 05-07-2021, 12:11 PM
Last Post: elimark1
Question Issues Installing NetBSD on a PineBook Pro ReleaseTheGeese 14 15,422 01-31-2021, 11:20 AM
  NetBSD -Current binaries BronzeBeard 8 11,848 12-31-2020, 08:38 PM
Last Post: BronzeBeard
Thumbs Up My NetBSD on Pinebook Pro journey KC9UDX 11 19,023 12-06-2020, 08:26 PM
