Getting access to an I2C bus? - Printable Version +- PINE64 (https://forum.pine64.org) +-- Forum: Pinebook Pro (https://forum.pine64.org/forumdisplay.php?fid=111) +--- Forum: Pinebook Pro Hardware and Accessories (https://forum.pine64.org/forumdisplay.php?fid=116) +--- Thread: Getting access to an I2C bus? (/showthread.php?tid=11603) |
Getting access to an I2C bus? - qMjbKsGg - 09-23-2020 Is there anywhere on the board where I would be able to tap into an I2C bus? Or does the board have any pads that are the equivalent of a 40-pin header with SDA/SDL pins/pads? RE: Getting access to an I2C bus? - Arwen - 09-24-2020 Pinebook Pros do not have a header or solder pads for expansion. That is something I'd like to see on the next version of the Pinebook Pro main board. The schematics are available on the Wiki site. If I can get help, I plan on making a replacement daughter / small board with extra features. Specifically a builtin 3v serial to USB adapter chip and MicroUSB port. Plus, possibly a second power switch on the right side. There are also 2 USB2 ports off an internal hub, (that has the Keyboard & Camera as the other 2 ports). That's something I'd like available on the main board's edge. RE: Getting access to an I2C bus? - qMjbKsGg - 09-24-2020 (09-24-2020, 01:38 PM)Arwen Wrote: Pinebook Pros do not have a header or solder pads for expansion. That is something I'd like to see on the next version of the Pinebook Pro main board. So regarding the schematics, what do the blue circles labeled with T## indicate? I’m not familiar with this symbol, and if it indicates a test point, I could reasonably tap into these. For example, the diagram at the bottom right of sheet 19 seems to indicate a pad that can be tapped into for SDA/SDL. RE: Getting access to an I2C bus? - Arwen - 09-25-2020 (09-24-2020, 04:11 PM)qMjbKsGg Wrote: ...I think that T## are probably test points. Which if on the top of the board, may make access for other uses easier. Those particular lines are used by the TrackPad & a small EEPROM used for the hardware kill switches. The keyboard controller chip, listed as U23 on that same page, is the parent controller. You probably want something off the main SoC. Trying to re-write the keyboard controller firmware to allow a third device on the TrackPad bus is likely to be pretty hard work. (There is someone who has dis-assembled much, if not all, the keyboard controller's firmware.) One other note. Many SoCs have multi-function I/O pins, which allow setting their function by software at boot. As an example, some AMD CPUs allow changing pins from PCIe lanes to SATA ports. So even though this SoC, Rockchip RK3399 may have several I2C buses, you need to make sure they are both available as I2C buses, and not used by something critical. Like power control or LCD backlight. |
