09-15-2020, 09:08 AM
scrcpy is a pretty cool app.. Using it to access my wallet apps from my old android phone over tcpip..Try it out to end up carrying just pinephone without worrying about missing android apps
Sxmo - Simple X Mobile Released for the Pinephone (new minimalistic UI & image)
09-16-2020, 11:14 AM
(07-30-2020, 12:46 PM)arjunaithal Wrote: The incoming calls not showing up even when I toggle modem. I'm using the latest sxmo image. The command to get the incoming calls - ( mmcli -m 0 --voice-list-calls -a) is not able to pick the incoming calls but the sms works fine. The other functionality is working as expected. The incoming calls is working fine in mobian and UT for the same Sim. Can someone please help? Thanks in advanceI think I have the exact same problem. Incoming calls did used to work for me and I'm not yet sure at what point it broke for me. I'll investigate further and see if I can solve it.
09-17-2020, 11:19 AM
(09-16-2020, 11:14 AM)proycon Wrote:(07-30-2020, 12:46 PM)arjunaithal Wrote: The incoming calls not showing up even when I toggle modem. I'm using the latest sxmo image. The command to get the incoming calls - ( mmcli -m 0 --voice-list-calls -a) is not able to pick the incoming calls but the sms works fine. The other functionality is working as expected. The incoming calls is working fine in mobian and UT for the same Sim. Can someone please help? Thanks in advanceI think I have the exact same problem. Incoming calls did used to work for me and I'm not yet sure at what point it broke for me. I'll investigate further and see if I can solve it. I have written custom scripts to get this working, with this fix I'm able to use my phone as daily driver without any issues and the latest fix of wakeup from crust on incoming call has increased the battery life significantly- https://lists.sr.ht/~mil/sxmo-devel/patches/13923 (getting almost 10-12 hrs on moderate usage) Custom script to monitor incoming call - sxmo_incomingcall.sh - A script scheduled in cron or sxmo_xinit.sh to monitor incoming calls using AT commands #!/usr/bin/env sh LOGFILE=/home/mo/.config/sxmo/modem/modemlog.tsv EVT_HANDLE="call_ringing" LOCKFILE=/home/mo/.config/sxmo/modem/ongoingcall.lock NOTIFDIR=/home/mo/.config/sxmo/notifications while [ 1 ] do if [ -f $LOCKFILE ]; then sleep 10 continue fi # WAKE=$(AT+QCFG="risignaltype","physical"|atinout - /dev/ttyUSB2 -) CALL=$(echo "AT+CLCC"|atinout - /dev/ttyUSB2 -) NUM=$(echo $CALL|perl -ne '$_=~ m/^.*\+91(.*)",145.*/;print $1;') if [ "$NUM" != "" ]; then TIME="$(date --iso-8601=seconds)" printf %b "$TIME\t$EVT_HANDLE\t$NUM\n" >> "$LOGFILE" printf %b "$NUM\n" > "$NOTIFDIR/sxmo_incomingcall" if [ -x "/home/mo/.config/sxmo/hooks/ring" ]; then "/home/mo/.config/sxmo/hooks/ring" & sxmo_vibratepine 2000 else sxmo_vibratepine 2000 fi else sxmo_setpineled green 0 fi sleep 3 done I have again used AT commands to receive and end calls using user defined script hooks. Command to accept call - ACCEPT=$(echo "ATA"|atinout - /dev/ttyUSB2 - 2>/dev/null) Command to end call - CALLEND=$(echo "AT+CHUP"|atinout - /dev/ttyUSB2 - 2>/dev/null) Command to start a call - START=$(echo "ATD+ +91$1;"|atinout - /dev/ttyUSB2 - 2>/dev/null) This way I don't use mmcli at all, it seems to be working without any issues.
Thanks! Doing it all without ModemManager is a very interesting solution!
I did manage to find a bit of a less intrusive solution (cross-posting from https://todo.sr.ht/~mil/sxmo-tickets/73): This requires less adaptation and doesn't ditch ModemManager: Starting modemmanager with a bit more verbosity helps (--debug also does the trick too but is even more verbose). Code: --- /etc/init.d/modemmanager I don't really understand why ModemManager fails without these options. I I had tried downgrading it but that didn't help either. For now this seems a pretty acceptable solution, having a log seems appropriate anyhow, so maybe we should merge this into sxmo (although it's technically not an sxmo issue).
09-25-2020, 12:46 PM
I love this! And would love to use sxmo as my daily driver. One thing I'm struggling with is getting the SIM to unlock automatically, or prompt me to. Thanks janw for the guide on NetworkManager - I think it'd work if I were to be able to get my modem online. I also submitted a ticket here: https://todo.sr.ht/~mil/sxmo-tickets/93#event-50869 about that and tried the solution to no avail. Any help with getting the modem running would be great. Thanks, and thanks again for creating such a promising OS.
09-26-2020, 01:35 AM
(This post was last modified: 09-28-2020, 01:07 AM by orneryeagle.)
@mil I'm having troubles both finding the merged sxmo packages and understanding how to install on top an existing pmOS. The install guide is missing details on what to do following the install of the `postmarketos-ui-sxmo` package to make use of SXMO, which can't be found in the default repos following an `apk update`. Does a user run `pmbootstrap`? Or can a user make use of the new UI without given an existing pmOS install?
09-30-2020, 07:14 PM
I love this project, it reminds me of i3wm but actually usable on touch screen devices.
I only wish that there were an Arch derivative with it (I heart my pacman)
after a day using it, I love it. there's a few issues, though
the camera doesn't seem to work, at least not from the system menu. I haven't tried any apps yet the audio section of the system menu doesn't work neither. pavucontrol works as expected. there's an intermittent hum sometimes from the phone. I'm not sure what that's about. there doesn't seem to be any access to any sort of app menu. the menu system relies on rofi, but there doesn't seem to be any shortcut or menu option to just access rofi's app menu there doesn't seem to be any clear way to alter the apps in the app menu. I suppose you could edit the sh file directly, but this should be separated to it's own file to personalize, so updates don't affect it there's no clear way to adjust the cellular modem settings. I'm not sure how to adjust APN settings, or enable data roaming (or enable/disable data). there's no way to adjust the delay of double and triple clicks of buttons. I find myself dragon ball mashing to get a triple click in. gestures take over app controls. swiping right to read in firefox switches virtual desktops for instance. personally id prefer to have a setting to disable them altogether. overall, this is everything I've been looking for in a mobile experience, it just needs some fine tuning.
10-04-2020, 10:21 AM
Quote:there doesn't seem to be any access to any sort of app menu. the menu system relies on rofi, but there doesn't seem to be any shortcut or menu option to just access rofi's app menuit uses dmenu. maybe try Alt-P to open it (it works for me, but I'm running my own build of dwm and svkbd so not sure if I've added in that shortcut) Quote:there doesn't seem to be any clear way to alter the apps in the app menu. I suppose you could edit the sh file directly, but this should be separated to it's own file to personalize, so updates don't affect itThere is a way to add userscripts if you put them in ~/.config/sxmo/userscripts then they will appear in the Scripts part of the menu. for some apps, if they are detected, then they will appear listed under Apps if installed. You could probably modify this patch https://lists.sr.ht/~mil/sxmo-devel/patches/12167 to include any additional apps. Quote:there's no way to adjust the delay of double and triple clicks of buttons. I find myself dragon ball mashing to get a triple click in.for triple clicks, you can just long press the button instead.
10-05-2020, 12:46 AM
theres no alt key, womp womp
Ill have to take a look at userscripts yeah, i usually long press but it doesnt work for sleep mode, and double clicks still hit or miss |
PostmarketOS sxmo pinephone keyboard keymaps? | afwtioane | 2 | 1,947 |
09-11-2022, 04:37 AM Last Post: manubert |
sxmo pim nextcloud | Uturn | 8 | 5,829 |
02-22-2022, 03:23 PM Last Post: TRS-80 |
Battery life on sxmo | xark | 1 | 2,028 |
02-12-2022, 10:07 AM Last Post: TRS-80 |
Official Channels for Sxmo Support | anjanmomi | 2 | 2,991 |
02-12-2022, 09:50 AM Last Post: TRS-80 |
sxmo & php | --- | 2 | 1,707 |
01-31-2022, 01:45 PM Last Post: --- |
sxmo improvements | unrealb2 | 7 | 5,500 |
11-17-2021, 06:43 AM Last Post: fdlamotte |
SXMO on Debian | IVp | 0 | 2,114 |
08-21-2021, 02:33 PM Last Post: IVp |
Megi's multiboot sxmo image | aithal | 1 | 2,126 |
06-14-2021, 08:07 AM Last Post: fdlamotte |
SXMO svkbd with joypad layout [for basic dosbox play] | streak | 0 | 1,440 |
05-27-2021, 08:47 AM Last Post: streak |
Sxmo on Arch | IVp | 4 | 6,257 |
05-19-2021, 03:18 AM Last Post: dukla2000 |
