04-21-2020, 08:09 AM
Every time I try to login I just get kicked back to the login screen. How do I fix this?
Stuck on login screen
04-21-2020, 08:53 AM
There's a lot of necessary information missing for anyone to be able to help you meaningfully.
What device are you using? And, what OS is it booting?
04-21-2020, 06:14 PM
Something tells me it's a Pinebook Pro.
Sounds like the desktop session is dying while it's trying to start up. Hit Ctrl+Alt+F1 to switch to a virtual terminal and see if you can log in on console. (Ctrl+Alt+F7 to go back to X11, i.e. the desktop.) Read through the various log files in /var/log/. Find the lines marked with the time of your login attempt, one or more of the files will likely report what's dying. Also, have you used this PBP before? If so, try to remember what you changed last time you were on. |
| Second screen mirroring | Fanche35 | 1 | 1,688 |
11-02-2023, 02:52 AM Last Post: randolphshaw4 |
| PinePower 120W Screen Issues | t-3 | 3 | 3,824 |
09-26-2022, 05:14 PM Last Post: superkamiguru |
| onscreen keyboard, screen locker and other tools(X) moved ! | jack1 | 0 | 1,885 |
08-10-2021, 03:19 PM Last Post: jack1 |
| Ugm, stuck in a loop | dgdimick | 2 | 4,787 |
03-19-2021, 05:42 AM Last Post: dgdimick |
| Pinecil stuck in shipping? | mbreese | 3 | 7,023 |
01-07-2021, 07:46 AM Last Post: moxx |
| smlock minimal screen locker | jack1 | 0 | 2,462 |
11-28-2020, 05:03 PM Last Post: jack1 |
| PineTime Dev Kits stuck in SHENZHEN | LinPhoneDev | 0 | 4,686 |
08-25-2020, 10:38 AM Last Post: LinPhoneDev |
| touch screen panel question | diggledorf | 1 | 4,121 |
08-23-2020, 06:09 PM Last Post: tllim |
| Forum Login Failure | neilman | 3 | 8,743 |
11-07-2019, 12:07 PM Last Post: tophneal |
| Forum login problems with Chromebook | jiyong | 4 | 7,934 |
08-09-2019, 04:36 AM Last Post: jiyong |
