Pinebook Pro structural integerity failing
#31
Well, the Pine64 people are learning. As has been said, the newer ones, (though it's unclear if it's ANSI only, or both ANSI & ISO), have a better plastic.
I've added a comment in the Wiki Troubleshooting on this issue. It's not very helpful, in the sense their is little to do, except replace. But, replacements are now available. And if someone wants to expand the Wiki section on this issue to include work arounds, repairs or outright re-enforcement, feel free.
Here is the section:
Wiki - Pinebook Pro - Cracks in the plastic
As usual, feel free to correct, improve or comment, (good or politely bad).
From what people have said, it made be possible to improve the structural integrity of the chassis using something like epoxy resin. I've ordered an ANSI keyboard replacement for my ISO model. Whence that arrives I may perform re-enforcement before I install it.
Arwen Evenstar
Princess of Rivendale
#32
(05-25-2020, 11:42 AM)Arwen Wrote: Well, the Pine64 people are learning. As has been said, the newer ones, (though it's unclear if it's ANSI only, or both ANSI & ISO), have a better plastic.
That's useful to know! Please post a guide to any reinforcement you do and link to it here-any advice helps.
#33
(05-25-2020, 04:52 AM).TDC_PBP Wrote:
(05-25-2020, 03:07 AM)vfr400racer Wrote:
(05-25-2020, 12:27 AM)hdk Wrote: My PBP broke again; the hinges came completely off. The palmrest is of extremely inferior quality.
The little plastic that holds the connection from screen to motherboard broke in 4 little peaces.
Support @ pine can or will not help in any way.
Disappointed adieu.
I bought a new one from the pine store. The recent ones are made of another plastic than the original ones. And they are only ~20USD.
Yes, but with shipping to the US they cost more like $32   Sad . While I am waiting for my replacement part, I have tried to glue my Pinebook Pro's crack near the hinge multiple times (the crack is on the upper left hand side of the keyboard) with regular Loctite, but it seems that it isn't strong enough, as it has cracked multiple times. I have bought Loctite's Plastics Bonding System from Amazon, and when I get it I plan on applying the glue on both the top and bottom of the crack and hoping for the best. This whole plastics thing is ridiculous!
I would suggest to modify the hinges, too. At least that is what I did. They are so hard to operate and put much stress on the tiny nuts and their fragile seatings.
#34
Disappointed adieu.
Amen to that! Make sure to post back in the forum if your modification works!
#35
My new palmrest came in today. I think it's better then the original.
I was ready for it: fixed the hinges, can now lift the screen with my pink.
The only hard part was the trackpad, had to use some force.
PBP out of the coma alive and kicking.
I'm in love again.
Will tell you my experiences in two weeks
#36
(06-15-2020, 01:56 PM)hdk Wrote: My new palmrest came in today. I think it's better then the original.
I'm in love again.
What modifications did you make to your PBP's hinges?
#37
I'm in love again.
Be patient, take your time
take the hinges off the screen, wrenching
make the hinges slowly wider, with a screwdriver 0,8 mm you can get in between the joint
#38
I'm in love again.
Ok, so I need to remove the hinges and then widen the hinges with a .8 mm screwdriver shaft-is that right?
#39
I'm in love again.
that's right
#40
I'm in love again.
that's right
Ok, thanks!
  looking to buy one pinebook pro (mainland China) duanduan 3 1,915 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 304 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 240 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 231 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 168 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 558 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 623 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,239 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,001 12-15-2023, 02:11 PM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 59,161 11-20-2023, 06:22 PM
