mobile data - always in use?
unfortunately i do not have the image anymore which i flashed, but i am very very sure it was a phosh image.
my login is "demo", so maybe i have some wierd demo image with some special settings or so? no idea.
I use phosh on debian ATM. And I also see settings > mobile, where I can disable mobile data.
That said, the strange thing with phosh is, that even when mobile (APN settings) is not configured right, or after I disabled "mobile data", it still show a "4G" at the status balk. This shows the impression that it is using mobile data while it's not the case. This is confusing.
Oh, and because this is a international forum and people don't speak the same language, some things may sound harder than it is meant Wink
I have the 4G above also.
Top of this settings page has a button labeled Mobile, which seems to be the phone itself.
under that is 'Network' with the 'Mobile Data' switch and a 'Data Roaming' switch
If I turn off the top 'Mobile' switch I kill all phone function
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(04-03-2020, 02:06 PM)bcnaz Wrote: If I turn off the top 'Mobile' switch I kill all phone function
Yes, you are right. When I switch off 'Mobile' at the top, 4G in the status balk also disappear.
  Gnome mobile user641 1 588 01-06-2024, 11:06 AM
Last Post: Uturn
  NextCloud Gnome Mobile Uturn 4 1,126 12-03-2023, 07:54 AM
Last Post: Uturn
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 743 10-03-2023, 06:32 PM
Question Always Use Mobile Data DingDangDoong 4 1,838 04-20-2023, 06:18 AM
Last Post: DingDangDoong
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 1,372 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 1 1,134 11-06-2022, 06:41 PM
Last Post: Chief
  No Application Data PMOS 21.12.1 Captain1ndustry 4 3,811 08-12-2022, 07:42 AM
Last Post: Gon
  Disable mobile data auto-enable on boot 64_Tesseract 3 2,254 08-11-2022, 02:48 AM
Last Post: 64_Tesseract
  wwan0 (cellular data) ip configuration is POINTTOPOINT not BROADCAST dc2daylight 0 1,049 04-07-2022, 07:16 PM
Last Post: dc2daylight
  Calls don't work on Softbank. Cellular data & SMS work. yasmi 1 1,587 03-24-2022, 04:10 AM
Last Post: yasmi
