Manjaro XFCE: video outputs (Multi-monitor)
Question
Connected USB type C to DP device: it works in mirror mode.
Manjaro XFCE only displays one video output: "default"
$ xrandr -q
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
default connected 1920x1080+0+0 0mm x 0mm
  1920x1080      0.00*
GUI settings ($ xfce4-display-settings -m): only one monitor ("default")
How to configure two separate monitors?
P.S. Default Debian: no problems (eDP-1 and DP-1 video outputs).
(03-22-2020, 11:37 AM)EreTIk Wrote: Connected USB type C to DP device: it works in mirror mode.
$ xrandr -q
  1920x1080      0.00*
that came up a few times on manjaro arm forums
the suggestion was swap drivers :
sudo pacman -S mesa-git
sudo pacman -R xf86-video-fbturbo # or xf86-video-fbturbo-git
then reboot
it worked for me Shy
Thank you very much
But without xf86-video-fbturbo-git, the rendering speed in xfreerdp is very low
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 3 44 6 hours ago
Last Post: calinb
  Manjaro update: nerd-font-terminus dependency issue Vinay 2 130 03-01-2023, 11:18 AM
Last Post: Vinay
  Manjaro update broke hardware video acceleration with mpv myself600 2 387 01-25-2023, 09:12 AM
Last Post: myself600
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 0 172 01-19-2023, 01:47 PM
Last Post: Cs137
  Streaming video sites tessa 0 166 01-14-2023, 01:58 PM
Last Post: tessa
  Manjaro ARM 20.04 spikerguy 68 80,962 01-08-2023, 07:22 PM
Last Post: vandys
  org.kde.plasma.core not installed (Manjaro) twirlip 0 191 01-06-2023, 09:47 AM
Last Post: twirlip
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 2 447 12-31-2022, 12:18 PM
Last Post: pine4546464
  PineBook HOW TO REINSTALL ARCH-Manjaro. Ice-O-Star 0 486 10-22-2022, 10:46 AM
Last Post: Ice-O-Star
  newer ""emmc-installer" images (manjaro xfce) magistral 1 500 10-10-2022, 06:22 AM
Last Post: maxjrh
