Requesting LCD Pinout Details
Just looking for a little more info on the pinout connecting the LCD driver to the MCU. The schematic showing the J7 connector shows some of the pins but they don't quite line up with the naming of the pins on from the LCD datasheet. I'm hoping to find definitions for each of the lines used for interfacing with the LCD driver. Obviously not the pins from the driver to the LCD..
Any clarification is appreciated. Thanks!
(03-20-2020, 09:50 PM)tayspen72 Wrote: Just looking for a little more info on the pinout connecting the LCD driver to the MCU. The schematic showing the J7 connector shows some of the pins but they don't quite line up with the naming of the pins on from the LCD datasheet. I'm hoping to find definitions for each of the lines used for interfacing with the LCD driver. Obviously not the pins from the driver to the LCD..
http://files.pine64.org/doc/datasheet/pi...0Panel.jpg
This is fantastic. Thank you tllim
Users browsing this thread:
